Duma Os is not running!
Doughboy
  • Replies 87
I used put in it and it gave me an invalid message. I don’t know how to do it the way it was explained on the website.
The exact command you should be using is:
tftp -i 192.168.1.1 put XR1000-V1.0.0.64_1.0.49.chk
If you get an error message with that, can you please show a screenshot of the error?
  • 3 weeks later...
It give me a error saying tftp: can’t read from local file ‘XR1000-V1.0.0.64_1.0.49.chk’
This page won’t allow me to send a screenshot.
Have you changed the directory on command prompt to the same place you have the file, for example if you have the file on your desktop the directory on command prompt should say desktop, for example like this:
It says desktop is not recognized as an internal or external command operable program or batch file
Did you put
cd
in front of it like my screenshot? This is covered in the guide, step 2 "Extract the ZIP file to your desktop. The firmware file format is either .img or .chk" and step 5 "Type cd desktop and press Enter to change the Command Prompt directory to your desktop." if you follow the guide step by step exactly that will get you sorted.
No I didn’t. I didn’t know I needed to do that I’ll try it again and see.
  • 2 weeks later...
This update is on .52. I spoke to you on Twitter and I suggested I use wifi. I updated it and did everything even set it up I’m wondering where this dos attack message is coming from. My computer is the 10.0.0.2.
Ok I figured it out. Omg… I was playing with the setting on the pa5 and I decided to change the mtu at the bottom from automatic to manual and change it to 1492. Instantly connected to psn. I can’t believe it.
It’s on the .52 update as well. I also made several changes just in case I have this issue with someone else. I changed my traffic prioritization to add my ps5. I also added the PlayStation network nat option on my fiber gateway and confirmed it. Don’t know if those two had anything to do with it but those were the changes I made. I also have att fiber.
Well done on getting it sorted and letting us know the solution! For whatever reason the router thinks your device is sending too much data to the router, that'll be something on the PC end causing that
