Duma Os is not running!
Doughboy
I updated my R2 router and when it came back up it shows duma os not running! Did the update brick my router? It doesn’t work even when I’ve reset it for 30 seconds I’ve unplugged it and everything
  • Replies 87
It’s working but I had to turn the wan stuff off in the beginning during start up. Also since I updated the router the ping heat map don’t work
Do you mean you had to disable IPv6? What do you mean by Ping Heatmap isn't working - the page isn't loading or when you select a game it isn't pinging the servers? If the latter resync the Heatmap cloud then try again please.
7 hours ago, Doughboy said:
Page isn’t loading
Can you clear your browsers cache now that you've completed the update and see if it works after that?
Nope Page isn’t loading it says this rapp is not loaded yet try again in a minute  can I go back to the original UI that I got with the R2 router because whenever I update the r2 or the xr1000 I have problems getting rapps to come up.
Go to the System Information page and then in the Rapp panel menu ≡ change the retries to 5, reboot from the interface, wait 2 minutes before accessing and see if it works then please.
Could you initiate a factory reset from the interface, wait 3 minutes, then access please and see if its all loading?
No because I can’t get to the interface. It’s a white screen that say that.
Do a reboot again so unplug power, wait 10 seconds, plug in, wait 2 minutes, then access and if you have access then do the factory reset
16 hours ago, Doughboy said:
I’ve done all that and still it shows Duma Os not running.
Since the reset, can you access the DumaOS interface if you use an incognito/private window in your browser?
  • 2 weeks later...
Yes I can. Can I just update it back to the original UI or the update that came with the router? I don’t see much difference between that and when I updated it besides it not functioning correctly since taking the new update?
Okay so it's possibly just a browser issue, go ahead and update, factory reset after then accessing using an incognito window again and see if it is working
Is there a way I can factory reset my xr 1000 or my R2 to default status? No updates or anything?
You can factory reset them but it would keep them on the same firmware, you would have to manually downgrade with the oldest firmware file of the two. I don't think it would be necessary to go all the way back. Sign up for early access here: https://forum.netduma.com/topic/39415-introducing-early-access/  and then you can try the R2 firmware there, followed by a factory reset to see if it is more stable for you.
Yeah because before I updated it it ran completely fine. Now it’s acting up.
I'd suggest signing up for the Early Access beta as Fraser mentioned, you can then try a newer firmware with bug fixes.
Yes it was. It’s a blank white screen and that’s what it says in the top left corner.
