Keep losing connection and these error codes keep popping up any ideas what they mean?
xiiMaGzx
What happens exactly, do all devices disconnect or specific devices? Does the connection return instantly, after a few seconds or do you have to reboot? Have you recently updated the firmware and if so did you do a factory reset afterwards?
It Sometimes just goes out for a bit then comes back out real quick. Also ye all devices at once through ethernet and wifi. I did reset after downloading the new firmware.
Immediately after the disconnect, can you download the log file from the three-line menu in the logs panel and send them over to us?
9 hours ago, xiiMaGzx said:
sure ill do it if it happens againlog-1658275239654.txt later. out of no where today my 5ghz wont work but my 2.4 does, idk why
Thanks, there's some good info in there. I'll pass this over to a developer to investigate and we'll let you know.
  • 5 months later...
