Issue with connecting to 2.5Ghz wifi
Sometimes I can't connect my kids laptops and Ipads to the 2.5Ghz wifi but the 5Ghz connects with no problem
Anyway to fix this?
Anyway to fix this?
Are they throwing any kinds of errors or complaints when this happens? Are you able to connect, but with no internet access? Or simply not connect at all?
If you can connect them, can they get to the DumaOS interface, despite not having an internet connection?
they show up on DumaOS but they don't connect to the internet when I select 2.5ghz channel on the device I'm trying to connect. 5ghz channel has no issue connecting any device.
It's telling me "unable to join the network" when I select it on the ipad and laptop
If they are older devices they may be having trouble with the WiFi security 2.4GHz is using, change that in settings and see if they can connect then
Both 2.5 and 5GHz networks have the same security options. WPA2-Personal AES
what should I change 2.5GHz too?
  • 3 weeks later...
Still having the same issue even when I change that option. All my devices only connect to the 5GHz channel. My phone is the only one that will connect to 2.5GHz
