Vipeeeer Posted June 9, 2022 Posted June 9, 2022 As above error message keeps popping up saying this rapp is not yet loaded xr500 feels very slow than usual lots of issues connection benchmark is giving a d for ping test qos won’t load just loads of error messages need this looked into
Netduma Liam Posted June 9, 2022 Posted June 9, 2022 If you reboot the XR, does everything then load normally again, at least temporarily? What firmware version are you currently running on the XR? If you've recently upgraded, make sure you factory reset it after the upgrade.
Vipeeeer Posted June 13, 2022 Author Posted June 13, 2022 Hi recently updated fw to latest and factory reset bufferbloat is always at C grade on dsl test use to be a+ across everything
Administrators Netduma Fraser Posted June 13, 2022 Administrators Posted June 13, 2022 Your QoS settings may need to be altered between firmware versions depending on what we change so I would recommend re-evaluating them and see what works best. Don't worry too much about the Connection Benchmark reading as we're still improving that.
Vipeeeer Posted June 13, 2022 Author Posted June 13, 2022 6 minutes ago, Netduma Fraser said: Your QoS settings may need to be altered between firmware versions depending on what we change so I would recommend re-evaluating them and see what works best. Don't worry too much about the Connection Benchmark reading as we're still improving that. It’s on the recommended 70/70 is this still the play for best results?
Administrators Netduma Fraser Posted June 13, 2022 Administrators Posted June 13, 2022 13 minutes ago, Vipeeeer said: It’s on the recommended 70/70 is this still the play for best results? 70/70 is our suggested starting point but that may not be the best for every connection so we do recommend experimenting with the percentages to see if you can get better results
