Kwee Posted March 15, 2022 Posted March 15, 2022 Just noticed under LAN Setup when I hit refresh on the menu it's giving 2 devices the same IP. example: Samsung tv will be 10.0.0.4 and my PC will be 10.0.0.4 as well. I'm pretty sure this was causing a conflict? Now that I changed the PC to 10.0.0.20 I don't see these issues anymore but I still notice it's using the same IP address again with some other device. 10.0.0.7
Netduma Liam Posted March 15, 2022 Posted March 15, 2022 Were you experiencing issues with the two devices? Did you check the IPs on each device and see if they'd genuinely both been given the same IP? It may just be a frontend issue.
Kwee Posted March 15, 2022 Author Posted March 15, 2022 I just did a factory reset on LAN AND WAN and problem is fixed. Just seem strange to me that it was handing out the same IP to 2 different devices
Administrators Netduma Fraser Posted March 15, 2022 Administrators Posted March 15, 2022 It's possible the IP was given to another device instead but it hadn't properly prevented the other from using it, should be a one off issue.
