no lan cable connected
fabigas
since two days My fifa game in ps4 days no lan cable connected and i loose connection while playing online.
cable is connected right.
what can i Do in the netduma?
That's a console specific issue so either the port in the console (or router) is damaged, in which case you could try another port on the router or the ethernet cable is faulty and that should be replaced. Other than that there are no specific settings on the router that would cause that to happen.
  • 3 weeks later...
IT is solved now.. the ethernet Port of the ps4 and ps5 seems a bit buggy. there is no click Sound when u put in the cable (all cable). when the console works it blows hot air an the back and can affect the cable in the Port for a second. It Was a well known Problem. no netduma issue :)
Interesting, OK thanks for letting us know. Do give us a shout if you need anything else.
