Uwais Posted January 15, 2022 Author Posted January 15, 2022 Okay got you, I’ll give it a go now and many thanks!
Uwais Posted January 16, 2022 Author Posted January 16, 2022 I don’t think the Geofilter is working for me.. whenever I make a change on the Dumaos it will say ‘This Rapp is taking longer than expected.’ Also it will only pick up servers whilst I’m connecting to online services in the COD Menu and once loaded in, the world map goes blank. I’m not sure if I need some sort of firmware update or if I’m just doing it wrong ://
Administrators Netduma Fraser Posted January 16, 2022 Administrators Posted January 16, 2022 You are on an older firmware, so I would recommend upgrading to this one https://forum.netduma.com/topic/38047-new-r2-firmware-30394/ it is much more stable. After the upgrade ~5 minutes after upload, do a factory reset from the interface and wait 2 minutes before accessing. From then on it should be much better for you!
Uwais Posted January 17, 2022 Author Posted January 17, 2022 Thank you so much, you guys have been so helpful, honestly would be clueless without you lol
