geofilter Not working on fifa 22
fabigas
Hallo netduma Team,
seit ein paar Tagen funktioniert der geofilter nicht mehr. Es wird selten bis nie der gegnerische Spieler oder der Server auf der Karte gezeigt. Zudem wird der autoping nicht gestartet und ich sehe die connection zum Gegner/ Server nicht.
auch wenn ich das filtern deaktiviere und ein Spiel suche, zeigt er mir nichts auf der Karte an.
was kann ich tun und wo liegt der Fehler?
habe die aktuellste Firmware.
Grüße
Welcome to the forum!
How have you added your device to Geo-filter? What platform are you playing on? Can you provide a full page screenshot of your Geo-filter setup?
Here is the Screenshot. i am searching for opponent and find him.but nothing shown in the geofilter.
ps4 connect via LAN, Filter enabled.
what can i Do?
Do this and then see if it works please:
  1. Quit the game completely - so go back to console dashboard
  2. Remove device from the Geo-Filter
  3. Resync from the Geo-Filter Map menu
  4. Re-add the device to the Geo-Filter with the manual option
  5. Set up the Geo-Filter how you like
  6. Wait 2 minutes
  7. Boot up game
i read this answer in the forum and Tried before.. in 8/10 games the geo Filter doesnt Show anything. just in few cases rsndomly i get the Information.
what can i Do?
Do you ever remove the device from the Geo-Filter and only add it back when the console/game is on? If so that would explain why icons don't always appear. Another potential could be if you leave your console in an instant on/power saving state, then powering it on may not trigger the Geo-Filter to detect that it is properly online
i did what u said but nothing. Filter is literally broken. worked in the First few days and now Not anymore.
need another solution.
here the logifle. i searched an opponent in 10:55 til 11:57 and found them. nothing shown in the filter
log-1638957467198.txt
by the way.. when i change configs in netduma sometimes the Router crashes and loose connection to Internet.
till now i dont See any advantage in this product
Could you please do the following:
  1. Remove the console from Geo-filter
  2. Power off the console and disconnect it's ethernet cable
  3. Go to Device Manager and click the PS5
  4. Delete the PS5
  5. Power the PS5 back on and reconnect ethernet cable
  6. Re-add it to Geo-filter
Let us know if this resolves the problem.
and every time i Touch the device Manager the netduma crashes. what a poor product. last try and then send IT back. Never had such a Bad product - disgusting
Did you factory reset after upgrading the firmware as it's not an issue that you should be having/is almost always resolved by the above steps
yeah i reset after Update to 3.0. 394
so it worked for the First days.. after plug in the ethernet again and delete in device Manager IT worked for few games.. than IT crashed again after adjusting the polygon Mode.
How is the console connected? Are you using automatic or manual network settings on it? Have you done port forwarding/using the DMZ etc?
connected with ethernet, IP Automatic, DHCP no, dns Google, mtu manuell
console is dmz in the netduma.
no forwarding but upnp and dmz
So you reserved an IP for it on the router? What MTU are you using? DMZ could cause it potentially as it does pass traffic straight through to the console. Can you remove it from that and use default MTU, restart the console and see whether it works please?
think i found the Bug.. whenever u enable a traffic prio rule for ps4"the Filter crashes and does Not Show Information. when disable IT works. maybe Check this for other customers
It's unlikely that otherwise everyone would be having the same issue - what rule did you do exactly, can you provide a screenshot please?
