BryceNTilla Posted November 17, 2021 Posted November 17, 2021 So as you know from twitter and other forums, i am having a ton of problems for some reason trying to upgrade to the latest firmware. Its a cycle. I try, it spins on the page saying it should take two minutes to complete, the page never reloads on its own, when i refresh the page, it says dumaos hasnt loaded yet. I am able to get on and play games and so on but cannot get into dumaos. When i factory reset after not being able to get into dumaos, it puts me on the firmware i am trying to get off of, says i am connected to the internet, when i open a new tab and try to get on youtube, twitch, twitter, ect., it says there is no internet connection which forces me to either try again with the firmware upgrade or factory reset again and try my luck with everything being normal (so far no luck). I would be more than happy to get into some sort of call on discord or something to further explain and i can share my screen so you can see the problem but this has been going on for awhile now.
Administrators Netduma Fraser Posted November 17, 2021 Administrators Posted November 17, 2021 I saw on Twitter you're trying to upgrade using a web browser I haven't seen/not familiar with, can you try upgrading using Google Chrome please and see if it works? If not we'll likely need to get a dev involved or have you run a command to force an upgrade
BryceNTilla Posted November 17, 2021 Author Posted November 17, 2021 Thank you Fraser. I just got back home from trying to upgrade through Chrome and the same issue. I let it run while i went out to do errands (30 to 45 mins long) and still spinning. I havent had issues with prior upgrades but this one just doesnt want to work for me.
Administrators Netduma Fraser Posted November 17, 2021 Administrators Posted November 17, 2021 Could you try this please: Deleting the firmware file from the PC, redownloading it then trying to upgrade again Downloading the previous firmware, then trying to upgrade to that
Administrators Netduma Fraser Posted November 17, 2021 Administrators Posted November 17, 2021 I mean delete it from the PC, like deleting a file you downloaded to your PC normally
BryceNTilla Posted November 17, 2021 Author Posted November 17, 2021 so just delete all the download files from my pc?
BryceNTilla Posted November 17, 2021 Author Posted November 17, 2021 I cant get to forums page to download it because its saying i have no internet connection
BryceNTilla Posted November 17, 2021 Author Posted November 17, 2021 tried to do what you said and still nothing, takes me to the page where it says it will only take 2 mins and then spins forever. refreshed the page and cant load dumaos.
Administrators Netduma Fraser Posted November 17, 2021 Administrators Posted November 17, 2021 Okay no worries, please enable remote support in Settings, disable IPv6 in LAN/WAN and we'll get the team to push an upgrade to you tomorrow
BryceNTilla Posted November 17, 2021 Author Posted November 17, 2021 will do, can you either post in here or or reach out to me on twitter to let me know when its pushed through?
BryceNTilla Posted November 17, 2021 Author Posted November 17, 2021 is this what it should look like?
Administrators Netduma Fraser Posted November 18, 2021 Administrators Posted November 18, 2021 Disable it in LAN as well just there on the left please, Liam will most likely post back here - you'll probably notice it happen as you'll lose connection. Make sure you post back here when you've done that from the R2 so we know what your IP is
Netduma Liam Posted November 18, 2021 Posted November 18, 2021 @BryceNTilla Hey, could you just post something here so I can see your IP? I'll need that to access your R2 and upgrade it.
Netduma Liam Posted November 18, 2021 Posted November 18, 2021 50 minutes ago, BryceNTilla said: By all means Did you hit 'Save general' after disabling IPv6? I'm still seeing an IPv6 address for you. Could you please make sure you're posting from behind the R2 as well.
BryceNTilla Posted November 18, 2021 Author Posted November 18, 2021 just turned IPv6 off on LAN and hit save general. this post is also from my computer under the R2 so should be good to go now
Netduma Liam Posted November 18, 2021 Posted November 18, 2021 20 minutes ago, BryceNTilla said: just turned IPv6 off on LAN and hit save general. this post is also from my computer under the R2 so should be good to go now I've just pushed an upgrade from the backend, in a few minutes please try to get back to the interface at 192.168.77.1 (You may have to clear browser cache first). You'll need to run through initial setup again so please bare in mind you won't have internet access until you've done this.
BryceNTilla Posted November 18, 2021 Author Posted November 18, 2021 Quote seem to be good to go then! looks like im on the correct firmware and my internet seems to be fine! appreciate the help! ill come back to this if something happens again, lets hope it doesnt haha
Administrators Netduma Fraser Posted November 18, 2021 Administrators Posted November 18, 2021 Brilliant to hear that, thanks for the update!
