Network Switch Recommendation Help
Hi,
I have a Netgear XR1000 and I’ve been thinking about getting a network switch for my 3 consoles and Apple TV. At the moment my Apple TV is getting spotty Wi-Fi and I’m getting a bit annoyed switching the Ethernet cable to whatever console I’m using. I was wondering if there’s a recommended switch to use for the XR1000 and if it would cause any issues with the router?
The Apple TV will be the only device which will be the only device that I’ll be putting on sleep, rather than turning off completely.
Any help would be much appreciated!
