Xr500 Hybrid vpn HMA basic not connecting
Netduma Fraser Please Help
Here are my logs.
I rejoined HMA today. I can log in on my pc. So it cant be wrong password or email.
VPN Logs
Fri Sep 24 10:15:20 2021 OpenVPN 2.4.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Dec 29 2020
Fri Sep 24 10:15:20 2021 library versions: OpenSSL 1.0.2n  7 Dec 2017, LZO 2.06
Fri Sep 24 10:15:20 2021 WARNING: --ns-cert-type is DEPRECATED.  Use --remote-cert-tls instead.
Fri Sep 24 10:15:20 2021 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Fri Sep 24 10:15:20 2021 TCP/UDP: Preserving recently used remote address: [AF_INET]209.239.115.186:553
Fri Sep 24 10:15:20 2021 Socket Buffers: R=[163840->163840] S=[163840->163840]
Fri Sep 24 10:15:20 2021 UDP link local: (not bound)
Fri Sep 24 10:15:20 2021 UDP link remote: [AF_INET]209.239.115.186:553
Fri Sep 24 10:15:20 2021 TLS: Initial packet from [AF_INET]209.239.115.186:553, sid=cacd0595 aacbdba8
Fri Sep 24 10:15:20 2021 WARNING: this configuration may cache passwords in memory -- use the auth-nocache option to prevent this
Fri Sep 24 10:15:20 2021 VERIFY OK: depth=1, C=UK, ST=London, L=London, O=Privax Ltd, OU=HMA Pro VPN, CN=hidemyass.com, [email protected]
Fri Sep 24 10:15:20 2021 VERIFY OK: nsCertType=SERVER
Fri Sep 24 10:15:20 2021 VERIFY OK: depth=0, C=UK, ST=London, L=London, O=Privax Ltd, OU=HMA Pro VPN, CN=server, [email protected]
Fri Sep 24 10:15:20 2021 Control Channel: TLSv1.2, cipher TLSv1/SSLv3 ECDHE-RSA-AES256-GCM-SHA384, 2048 bit RSA
Fri Sep 24 10:15:20 2021 [server] Peer Connection Initiated with [AF_INET]209.239.115.186:553
Fri Sep 24 10:15:21 2021 SENT CONTROL [server]: 'PUSH_REQUEST' (status=1)
Fri Sep 24 10:15:21 2021 AUTH: Received control message: AUTH_FAILED
Fri Sep 24 10:15:21 2021 SIGTERM[soft,auth-failure] received, process exiting
Xr500 duma regular logs
[DumaOS] config write 'com.netdumasoftware.hybridvpn.settings', Friday, September 24, 2021 02:19:45
[DumaOS] Backing up settings to config partition., Friday, September 24, 2021 02:19:45
[Log Cleared] Friday, September 24, 2021 02:18:17
32 minutes ago, Netduma Liam said:
Are you setting up the VPN with the basic configuration, or the advanced? Are you getting the same issue if you try VPNing to a different location?
Im setting up as Basic.
I have same issue trying to VPNing all locations.
Id like to note ive tried the current public firmware and V2.3.2.56 both to see if i can get basic hma to work. Its not working on either
Ohhh Sorry guys i got it working. My error. I guess its from being up so late. Lack of sleep. Id hate to say the issue... Hma website allows email to be used to login. Duma os vpn does not allow email to be used in hma login. have to use username which is basically the same as email without the @gmail part.  I appologize if i wasted any of your time. I over looked and extremly tired....
No worries, well done on getting it sorted and letting us know the solution. I'll close the topic for now, feel free to open another if needed and we'll be happy to help.
