Setting up router with Virgin Suber Hub
lenere118
sorry for late reply. if you are leaving your sh in router mode then place the ip assigned to the R2 by the sh into the DMZ of the sh and then make that ip address static. Disable wifi on the sh also. I think you can also disable DHCP on the sh once your R2 has a static ip address.
When in modem mode i am sure only 1 ethernet port will work at any one time on the SH3
yes, it is lan 1.
1 hour ago, lenere118 said:
Okay now its finally working, flipping it into modem mode is working. This is weird.
Great to hear that, tech can be funny sometimes! As BD mentioned above you could put the R2 in the VM DMZ when in router mode and that would prevent a double NAT.
Will consider this thread resolved and closed.
