need help setting up router please
hi guy im new here. my router arrived today but i cant seem to get power to it, ive followed the instrutions guide step by step but cant seem to get power or lights on router. if someone could kindly take the time to help me i would be really happy.
quinten
Sorry to hear you're having this issue. Try direct to a wall outlet as well as through an extender. If that doesn't work see if you have a power adapter with the same connection type and voltage and see if it works - it could be the power adapter is faulty.
i tried another 12v power supply and i have light on the router, im going to try my best to set up now. is there anything i should now tips.... for setup
Brilliant to hear that, so we must have sent a faulty power adapter, sorry about this. Run through the setup wizard and connect ALL devices to the router. Make sure you run through all the tours available to you - the general tour and Rapp specific tours and read all the information it provides so you can understand how it works and how to get the best out of it. Any questions let us know and we'll be happy to help.
hey fraser. im connected to the wifi on my laptop atm but when seting up i was prestented with a never eneding spinning loading screen so i closed the window, seems to appear that i have established a connection but when trying to connect via ethernet cable to my desktop pc i cant seem to get internet or connection. i also cant get connected on my xbox one ether
At what point in the Setup Wizard did you see it loading constantly? Reboot the router and then try and connect again please
