Problem geofiltri Destiny 2
Axel
7 hours ago, OzQuant said:
Mirabile dictu! How do I go about doing this on R1? I have the old firmware (v1.x), do I need to flash the new v2 firmware?
No you don't need to upgrade, it is a cloud update so it should have updated automatically by now but if you resave the cloud in Settings > Miscellaneous you'll definitely have it
6 hours ago, Chopman said:
Will flushing cloud mess up beta update?
No it won't, you are safe to do so
  • Replies 53
@Netduma Fraser will this work on duma os 3? I remember back a few months ago geo filtering was not working for me on os 3 so I had to down grade.
Yes it will, we have pushed another cloud update so you can flush/re-sync the cloud and you should be able to filter servers
Thank you. About 2 months ago the 3.0 didn’t work with geo filter.
