Internet speed difference R2 router and Vodafone EMTA 3.1 1g modem
Ludwig1981
Hi!
My problem is that R2 router has a different Internet download speed than the Internet modem provider.
Interestingly that uploading is the same but the download speed is not!
I use Vodafone modem in Bridge mode to the router.
QoS is turned off on the router.
What can cause the problem?
The pictures show the difference well.
screenshot-192_168_77.1-2021_04_04-13_36_34.thumb.jpg.262b02f31cab2d193f6ea0b030103989.jpg
screenshot-www.vodafone.hu-2021_04_04-13_37_16.thumb.jpg.68d9dbb8412118402461f1d9e5071a65.jpg
screenshot-www.speedtest.net-2021_04_04-13_38_49.thumb.jpg.b55fd6fb53f8196c7895a47ed359b3ce.jpg
974383875_singleconnection2-www.speedtest.net-2021_04_04-13_42_12.thumb.jpg.b5893c785251d7d11b237288266bc9d9.jpg
What speed do you get on speedtest.net when connected directly to the R2?
Hello!
All the measurements you see through the R2 router.
In the first picture you see what R2 is measuring through your own dashboard.
The 2-3 images are measured on another Internet speedometer page.
Figure 4 is Single Connection Internet Speed Measurement.
Why is the R2 Router Dashboard 282 Mbps download speed and why does the SpeedTest 809 Mbps measure?
The Internet speed was 900-1000 Mbps via Vodafone modem.
When I put the modem into Bridge mode and connected to the R2 router my internet was less (600-800Mbps SpeedTest.net)
The R2 router dashboard measures 250-320 Mbps.
This is my problem!
Ah I see, thanks for clarifying. We're still improving upon the speedtest shown on Connection Benchmark it uses different servers as opposed to Ookla. The speeds you're getting through speedtest.net on the R2 are probably the highest you will achieve through the router
Compared to the modem internet, 100-200 Mbps are also lost.
What can be done to make my internet faster through the R2 router?
If you have disabled QoS fully from the Congestion Control 3 line option menu on the QoS page then that will be the maximum speed you can get through the R2 if there are no other devices connected to the ISP router
