MrJack Posted March 17, 2021 Posted March 17, 2021 DumaOS Routers Owned: Netduma R2 Hello I have a question. I always used this program Called ExitLag before I got my NetDuma R2 I have had issues connecting to desired servers since I live in Honduras central america I have wait times of 5+minutes even to the closest server to me that is Miami 25-35 ms. So a friend told me is probably because im not in the actual state living there that I try to get pushed out. So I loaded my exitlag to put my location on dallas to connect to dallas. But I had my geo filter ON and it didnt seem to work at all when I was using exit lag it started taking me to servers that are out of circle using exitlag. When I removed exitlag and searched a match without it I waited 10+mins to connect to a dallas server but the point is that Why when I am using exitlag the filter doesnt work????? Any ideas to make it work ???
Netduma Liam Posted March 17, 2021 Posted March 17, 2021 Welcome to the forum! Are you playing on your PC or on a separate console? If you disable Geo-filter, do you experience the same issue? Could you also please provide a screenshot of your Geo-filter?
MrJack Posted March 18, 2021 Author Posted March 18, 2021 On 3/17/2021 at 6:53 AM, Netduma Liam said: Welcome to the forum! Are you playing on your PC or on a separate console? If you disable Geo-filter, do you experience the same issue? Could you also please provide a screenshot of your Geo-filter? Yes im playing on PC. If I disable geo filter I dont experience the same but I want to use it with geo filter.
Administrators Netduma Fraser Posted March 18, 2021 Administrators Posted March 18, 2021 Thank you, can you provide a full screen picture of the Geo-Filter please instead of a cropped version?
MrJack Posted March 18, 2021 Author Posted March 18, 2021 6 hours ago, Netduma Fraser said: Thank you, can you provide a full screen picture of the Geo-Filter please instead of a cropped version?
Administrators Netduma Fraser Posted March 18, 2021 Administrators Posted March 18, 2021 Everything is set correctly there, it is likely the VPN tunnel is bypassing the Geo-Filter as it can't see the traffic properly to filter it - can you show what you see when you're getting games outside your areas please?
BigBoy Posted July 14, 2021 Posted July 14, 2021 On 3/18/2021 at 6:16 PM, Netduma Fraser said: Everything is set correctly there, it is likely the VPN tunnel is bypassing the Geo-Filter as it can't see the traffic properly to filter it - can you show what you see when you're getting games outside your areas please? Hello, how do I contact you with help regarding ExitLag and netduma? I want to use the hybrid vpn section and input the ExitLag config files
Administrators Netduma Fraser Posted July 15, 2021 Administrators Posted July 15, 2021 14 hours ago, BigBoy said: Hello, how do I contact you with help regarding ExitLag and netduma? I want to use the hybrid vpn section and input the ExitLag config files You're doing so now! Would be best to make an entirely new topic though regarding this, do they have config files or do they just have the program?
