MRxFUZZ Posted February 15, 2021 Posted February 15, 2021 Having issues with the Connection benchmark app where it only test my full connection speeds and not the bandwidth set in QOS. I was trying to read the forums about this issue but couldnt find anything about it. If anyone could help I would really appreciate it, thanks.
Netduma Liam Posted February 15, 2021 Posted February 15, 2021 Connection benchmark will bypass QoS in the Speed test stage, however if you do a third part speedtest such as speedtest.net, you will be able to see QoS working. On a side note, looks like you could do with optimising your QoS a little bit! Could you provide a screenshot of your Congestion Control and I'll try make some suggestions!
MRxFUZZ Posted February 16, 2021 Author Posted February 16, 2021 I used to get all A+ with these settings on the R2 and it would go along with my QOS setting when they were changed. Then wouldnt that app be pointless if it didnt run with your QOS applied ? It would just be a regular speed test.
Netduma Liam Posted February 16, 2021 Posted February 16, 2021 That's strange, I'd suggest setting it to 'Always' and change the sliders in 5% increments and re-testing to find what give you the best score! The first graph is a regular speedtest, the third graph is what tells you if QoS is working properly.
MRxFUZZ Posted February 22, 2021 Author Posted February 22, 2021 I have changed the QOS slider all the way to 5 percent and set it to always on, still get the same results.
Netduma Liam Posted February 23, 2021 Posted February 23, 2021 How strange, what version are you currently running?
MRxFUZZ Posted February 23, 2021 Author Posted February 23, 2021 I am running the 3.0 beta version at this moment.
Administrators Netduma Fraser Posted February 23, 2021 Administrators Posted February 23, 2021 If the same settings worked really well on the R2 then use those same settings. We're looking into anomalous results on the Ping Under Load XR test results, I don't think it will actually be that high.
MRxFUZZ Posted February 23, 2021 Author Posted February 23, 2021 All those images are the results from the XR700 with the beta firmware. Any settings I put the QOS at I get the same D- score.
Administrators Netduma Fraser Posted February 24, 2021 Administrators Posted February 24, 2021 As above, we're looking into anomalous results on the Ping Under Load XR test results, I don't think it will actually be that high so just use the R2 settings you know work. If it really was that high you would be having terrible games anytime someone watches a video while you're gaming for example.
