XR500 drops all WiFi and LAN connections at random
Started every few days a few weeks ago, now its dozens of times a day.  The white status light turns red.  It takes anywhere from a  minute to 10 or 20 to come back online.  I can unplug and reset the router to get it working again.
Firmware VersionV2.3.2.66
I cleared and started a fresh log and will add that soon
Welcome to the forum!
Could you try setting a static route to your XR from the ISP router/modem's admin page?
Also, In Settings > Monitoring > Connection Status what is the DHCP lease obtained and expired times?
Lease Obtained 3 Days, 4 Hours, 24 Minutes
Lease Expires 3 Days, 3 Hours, 30 Minu
Will change the router settings right now
On 2/2/2021 at 5:50 AM, Netduma Liam said:
OK, do you still have access to the interface when a drop occurs? If so, do you notice any entries in the logs around these times?
Short answer no.  When it drops out I lose connection to the router completely via LAN.
UPDATE  As of yesterday the drop outs stopped.  EXCEPT now my 2.4ghz network shows online on the dashboard but nothing can connect to it.  My 5ghz and LAN network is fine
I was busy at work all day my logs don't seem to go back far enough to pull the last disconnect
2 minutes ago, Netduma Fraser said:
That's weird, is it only 2.4GHz devices that drop out?
Correct!  5ghz was completely unaffected
Interesting, do you have any wireless or electrical devices near the router? It sounds like a weird question but do you have a microwave nearby and do you notice it when the microwave is used?
Nope.  It happens at random times when we are not home or the middle of the night
There is a WiFi analyzer app on Windows in the Microsoft store for free, connect your PC via 2.4GHz and then run it and post a screenshot please so I can have a look.
It looks like this:
So on my networks on windows I don't see an option to select just the 2.4ghz network.  I put the app on my surface.  Also as of this moment my router logs only go back about 4 hours.  Is that normal?
Are you using SmartConnect on the XR? You can check this in Network Settings.
When was the last dropout? You logs would be clear when the router reboots, so if your last drop was 4 hours ago that would make sense.
Did you get a chance to try the Wi-Fi analyser as Fraser suggested?
Smart connect is on.
I did but he asked to connect to the 2.4ghz network and I only can select the 5
so you are right the router is rebooting and clearing logs.  The last drop was 30 minutes ago and I cant see anything before it restarted
Spoiler
[DumaOS] DHCP new lease allocated., Thursday, February 04, 2021 06:30:15
[DumaOS] DHCP new event., Thursday, February 04, 2021 06:30:15
[DHCP IP: 192.168.1.22] to MAC address 8c:85:90:21:12:de, Thursday, February 04, 2021 06:30:15
[DumaOS] DHCP lease change., Thursday, February 04, 2021 06:30:09
[DumaOS] DHCP new event., Thursday, February 04, 2021 06:30:09
[DHCP IP: 192.168.1.12] to MAC address 00:04:20:fd:e2:61, Thursday, February 04, 2021 06:30:09
[DumaOS] DHCP new lease allocated., Thursday, February 04, 2021 06:28:36
[DumaOS] DHCP new event., Thursday, February 04, 2021 06:28:36
[DHCP IP: 192.168.1.20] to MAC address d8:cb:8a:3a:3e:93, Thursday, February 04, 2021 06:28:36
[DoS Attack: SYN/ACK Scan] from source: 178.32.181.251, port 105, Thursday, February 04, 2021 06:28:35
[DumaOS] DHCP lease change., Thursday, February 04, 2021 06:27:35
[DumaOS] DHCP new event., Thursday, February 04, 2021 06:27:35
[DHCP IP: 192.168.1.17] to MAC address a0:40:a0:73:fb:19, Thursday, February 04, 2021 06:27:35
[DoS Attack: ARP Attack] from source: 98.224.100.1, Thursday, February 04, 2021 06:25:20
[DumaOS] DHCP lease change., Thursday, February 04, 2021 06:25:09
[DumaOS] DHCP new event., Thursday, February 04, 2021 06:25:09
[DHCP IP: 192.168.1.12] to MAC address 00:04:20:fd:e2:61, Thursday, February 04, 2021 06:25:09
[DumaOS] DHCP lease change., Thursday, February 04, 2021 06:20:11
[DumaOS] DHCP new event., Thursday, February 04, 2021 06:20:11
[DHCP IP: 192.168.1.12] to MAC address 00:04:20:fd:e2:61, Thursday, February 04, 2021 06:20:11
[DumaOS] DHCP lease change., Thursday, February 04, 2021 06:20:10
[DumaOS] DHCP new event., Thursday, February 04, 2021 06:20:10
[DHCP IP: 192.168.1.12] to MAC address 00:04:20:fd:e2:61, Thursday, February 04, 2021 06:20:10
[DoS Attack: TCP/UDP Echo] from source: 75.75.76.76, port 53, Thursday, February 04, 2021 06:18:09
[DoS Attack: TCP/UDP Echo] from source: 75.75.75.75, port 53, Thursday, February 04, 2021 06:18:09
[DoS Attack: TCP/UDP Echo] from source: 75.75.76.76, port 53, Thursday, February 04, 2021 06:18:07
[DoS Attack: TCP/UDP Echo] from source: 75.75.75.75, port 53, Thursday, February 04, 2021 06:18:07
[DoS Attack: TCP/UDP Echo] from source: 75.75.75.75, port 53, Thursday, February 04, 2021 06:18:06
[DumaOS] DHCP lease change., Thursday, February 04, 2021 06:15:12
[DumaOS] DHCP new event., Thursday, February 04, 2021 06:15:12
[DHCP IP: 192.168.1.12] to MAC address 00:04:20:fd:e2:61, Thursday, February 04, 2021 06:15:12
[DoS Attack: ARP Attack] from source: 98.224.100.1, Thursday, February 04, 2021 06:15:10
[DumaOS] DHCP lease change., Thursday, February 04, 2021 06:12:33
[DumaOS] DHCP new event., Thursday, February 04, 2021 06:12:33
[DHCP IP: 192.168.1.17] to MAC address a0:40:a0:73:fb:19, Thursday, February 04, 2021 06:12:33
[DumaOS] DHCP lease change., Thursday, February 04, 2021 06:10:10
[DumaOS] DHCP new event., Thursday, February 04, 2021 06:10:10
[DHCP IP: 192.168.1.12] to MAC address 00:04:20:fd:e2:61, Thursday, February 04, 2021 06:10:10
[DumaOS] DHCP new lease allocated., Thursday, February 04, 2021 06:09:54
[DumaOS] DHCP new event., Thursday, February 04, 2021 06:09:54
[DHCP IP: 192.168.1.16] to MAC address 82:b9:d4:e0:d1:fd, Thursday, February 04, 2021 06:09:54
[DoS Attack: ARP Attack] from source: 192.168.1.21, Thursday, February 04, 2021 06:06:55
[DoS Attack: RST Scan] from source: 43.224.226.17, port 37301, Thursday, February 04, 2021 06:06:23
[DumaOS] DHCP lease change., Thursday, February 04, 2021 06:05:12
[DumaOS] DHCP new event., Thursday, February 04, 2021 06:05:12
[DHCP IP: 192.168.1.12] to MAC address 00:04:20:fd:e2:61, Thursday, February 04, 2021 06:05:12
[DoS Attack: ARP Attack] from source: 98.224.100.1, Thursday, February 04, 2021 06:05:00
[DumaOS] DHCP lease change., Thursday, February 04, 2021 06:00:24
[DumaOS] DHCP new event., Thursday, February 04, 2021 06:00:24
[DHCP IP: 192.168.1.12] to MAC address 00:04:20:fd:e2:61, Thursday, February 04, 2021 06:00:24
[DumaOS] DHCP new lease allocated., Thursday, February 04, 2021 05:57:32
[DumaOS] DHCP new event., Thursday, February 04, 2021 05:57:32
[DHCP IP: 192.168.1.17] to MAC address a0:40:a0:73:fb:19, Thursday, February 04, 2021 05:57:32
[DumaOS] DHCP lease change., Thursday, February 04, 2021 05:57:00
[DumaOS] DHCP new event., Thursday, February 04, 2021 05:57:00
[DHCP IP: 192.168.1.12] to MAC address 00:04:20:fd:e2:61, Thursday, February 04, 2021 05:57:00
[DumaOS] DHCP new lease allocated., Thursday, February 04, 2021 05:56:44
[DumaOS] DHCP new event., Thursday, February 04, 2021 05:56:44
[DHCP IP: 192.168.1.13] to MAC address 00:fc:8b:46:d7:99, Thursday, February 04, 2021 05:56:44
[DumaOS] DHCP new lease allocated., Thursday, February 04, 2021 05:56:19
[DumaOS] DHCP new event., Thursday, February 04, 2021 05:56:19
[DHCP IP: 192.168.1.14] to MAC address 90:dd:5d:7e:6b:51, Thursday, February 04, 2021 05:56:19
[DumaOS] DHCP lease change., Thursday, February 04, 2021 05:56:09
[DumaOS] DHCP new event., Thursday, February 04, 2021 05:56:09
[DHCP IP: 192.168.1.26] to MAC address e4:5e:37:de:d6:59, Thursday, February 04, 2021 05:56:09
[DumaOS] DHCP new lease allocated., Thursday, February 04, 2021 05:56:09
[DumaOS] Ubus object 'com.netdumasoftware.geofilter' added, attempting to bind pending, Thursday, February 04, 2021 05:55:05
[DumaOS] Ubus object 'com.netdumasoftware.qos' added, attempting to bind pending, Thursday, February 04, 2021 05:55:05
[DumaOS] Ubus object 'com.netdumasoftware.hybridvpn' added, attempting to bind pending, Thursday, February 04, 2021 05:55:05
[DumaOS] Ubus object 'com.netdumasoftware.devicemanager' now bound, Thursday, February 04, 2021 05:55:05
[DumaOS] applying qos for zone lan, Thursday, February 04, 2021 05:55:00
[DumaOS] applying qos for zone wan, Thursday, February 04, 2021 05:54:59
[DumaOS] Ubus object 'com.netdumasoftware.qos' added, attempting to bind pending, Thursday, February 04, 2021 05:54:55
[DumaOS] Ubus object 'com.netdumasoftware.hybridvpn' added, attempting to bind pending, Thursday, February 04, 2021 05:54:55
[DumaOS] Ubus object 'com.netdumasoftware.devicemanager' now bound, Thursday, February 04, 2021 05:54:55
[DumaOS] NSS delete root for interface 'br0', Thursday, February 04, 2021 05:54:54
[DumaOS] applying qos for zone lan, Thursday, February 04, 2021 05:54:54
[DumaOS] NSS delete root for interface 'brwan', Thursday, February 04, 2021 05:54:54
[DumaOS] applying qos for zone wan, Thursday, February 04, 2021 05:54:54
[DumaOS] DHCP new lease allocated., Thursday, February 04, 2021 05:54:53
[DumaOS] DHCP new event., Thursday, February 04, 2021 05:54:53
[DHCP IP: 192.168.1.11] to MAC address b0:02:47:7b:69:a9, Thursday, February 04, 2021 05:54:53
[DumaOS] Ubus object 'com.netdumasoftware.hybridvpn' added, attempting to bind pending, Thursday, February 04, 2021 05:54:50
[DumaOS] Ubus object 'com.netdumasoftware.devicemanager' added, attempting to bind pending, Thursday, February 04, 2021 05:54:50
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Thursday, February 04, 2021 05:54:50
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Thursday, February 04, 2021 05:54:50
[DumaOS] Ubus object 'com.netdumasoftware.devicemanager' now bound, Thursday, February 04, 2021 05:54:50
[DumaOS] Geo-Filter cloudsync result 'true','Geo-Filter is up to date', Thursday, February 04, 2021 05:54:49
[DumaOS] Ubus object 'com.netdumasoftware.rappstore' added, attempting to bind pending, Thursday, February 04, 2021 05:54:49
[DumaOS] All dependencies loaded, starting, Thursday, February 04, 2021 05:54:49
[DumaOS] Dependency loaded 'com.netdumasoftware.devicemanager', Thursday, February 04, 2021 05:54:49
[DumaOS] Ubus object 'com.netdumasoftware.devicemanager' added, attempting to bind pending, Thursday, February 04, 2021 05:54:49
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending, Thursday, February 04, 2021 05:54:46
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound, Thursday, February 04, 2021 05:54:46
[DumaOS] Cloudsync DPI result 'false','All mirrors are down', Thursday, February 04, 2021 05:54:46
[DumaOS] DHCP new lease allocated., Thursday, February 04, 2021 05:54:44
[DumaOS] DHCP new event., Thursday, February 04, 2021 05:54:44
[DHCP IP: 192.168.1.10] to MAC address b8:5f:98:2d:7d:85, Thursday, February 04, 2021 05:54:44
[DumaOS] Ubus object 'com.netdumasoftware.rappstore' added, attempting to bind pending, Thursday, February 04, 2021 05:54:44
[DumaOS] Ubus object 'com.netdumasoftware.rappstore' added, attempting to bind pending, Thursday, February 04, 2021 05:54:43
[DumaOS] Ubus object 'com.netdumasoftware.autoadmin' added, attempting to bind pending, Thursday, February 04, 2021 05:54:43
[DumaOS] Ubus object 'com.netdumasoftware.desktop' added, attempting to bind pending, Thursday, February 04, 2021 05:54:43
[DumaOS] Ubus object 'com.netdumasoftware.neighsync' added, attempting to bind pending, Thursday, February 04, 2021 05:54:43
[DumaOS] Ubus object 'com.netdumasoftware.networkmonitor' added, attempting to bind pendin, Thursday, February 04, 2021 05:54:43
[DumaOS] App 'com.netdumasoftware.rappstore' initialised & starting., Thursday, February 04, 2021 05:54:43
[DumaOS] R-App store cloud sync failed, Thursday, February 04, 2021 05:54:43
[DumaOS] HTTP download failed with code '404', Thursday, February 04, 2021 05:54:43
[DumaOS] Resync R-App store cloud, Thursday, February 04, 2021 05:54:43
[DumaOS] Dependency loaded 'com.netdumasoftware.autoadmin', Thursday, February 04, 2021 05:54:43
[DumaOS] App 'com.netdumasoftware.autoadmin' initialised & starting., Thursday, February 04, 2021 05:54:43
[DumaOS] All dependencies loaded, starting, Thursday, February 04, 2021 05:54:43
[DumaOS] App 'com.netdumasoftware.desktop' initialised & starting., Thursday, February 04, 2021 05:54:43
[DumaOS] Cloudsync Themes result 'false','All mirrors are down', Thursday, February 04, 2021 05:54:42
[DumaOS] Ubus object 'com.netdumasoftware.neighsync' added, attempting to bind pending, Thursday, February 04, 2021 05:54:42
[DumaOS] Ubus object 'com.netdumasoftware.networkmonitor' added, attempting to bind pendin, Thursday, February 04, 2021 05:54:42
[DumaOS] App 'com.netdumasoftware.neighsync' initialised & starting., Thursday, February 04, 2021 05:54:42
[DumaOS] App 'com.netdumasoftware.devicemanager' initialised & starting., Thursday, February 04, 2021 05:54:42
[DumaOS] Waiting for 'com.netdumasoftware.autoadmin' to run before starting, Thursday, February 04, 2021 05:54:42
[DumaOS] pending subscription for package 'com.netdumasoftware.dpiclass', Thursday, February 04, 2021 05:54:42
[DumaOS] subscribe to 'com.netdumasoftware.neighwatch' from 'com.netdumasoftware.devicemanager, Thursday, February 04, 2021 05:5
[DumaOS] App 'com.netdumasoftware.hybridvpn' initialised & starting., Thursday, February 04, 2021 05:54:41
[DumaOS] Waiting for 'com.netdumasoftware.autoadmin' to run before starting, Thursday, February 04, 2021 05:54:41
[DumaOS] Waiting for 'com.netdumasoftware.devicemanager' to run before starting, Thursday, February 04, 2021 05:54:41
[DumaOS] pending subscription for package 'com.netdumasoftware.devicemanager', Thursday, February 04, 2021 05:54:41
[DumaOS] Ubus object 'com.netdumasoftware.networkmonitor' added, attempting to bind pendin, Thursday, February 04, 2021 05:54:41
[DumaOS] App 'com.netdumasoftware.networkmonitor' initialised & starting., Thursday, February 04, 2021 05:54:41
[DumaOS] App 'com.netdumasoftware.geofilter' initialised & starting., Thursday, February 04, 2021 05:54:41
[DumaOS] pending subscription for package 'com.netdumasoftware.dpiclass', Thursday, February 04, 2021 05:54:41
[DumaOS] App 'com.netdumasoftware.qos' initialised & starting., Thursday, February 04, 2021 05:54:41
[DumaOS] Ubus object 'com.netdumasoftware.systeminfo' added, attempting to bind pending, Thursday, February 04, 2021 05:54:40
[DumaOS] App 'com.netdumasoftware.systeminfo' initialised & starting., Thursday, February 04, 2021 05:54:40
[DumaOS] Ubus object 'com.netdumasoftware.neighwatch' added, attempting to bind pending, Thursday, February 04, 2021 05:54:40
[DumaOS] App 'com.netdumasoftware.neighwatch' initialised & starting., Thursday, February 04, 2021 05:54:40
[DumaOS] DHCP new lease allocated., Thursday, February 04, 2021 05:54:40
[DumaOS] DHCP new event., Thursday, February 04, 2021 05:54:40
Okay disable Smart Connect please first of all, then connect devices manually to either 2.4 or 5GHz and see if you get the same issue. If you do then do my suggestion above and post the screenshot please.
54 minutes ago, BCNorgard said:
I can't see your screenshots, could you provide a link to them or upload as a zip please?
On the last router reboot after disabling Smart Connect (so it didn't work)  no devices ether 5ghz or 2.4ghz could reconnect.  I enabled smart connect again and rebooted.  Now both networks are up again for now
WiFi Screen Shots.zip
OK so now both 2.4GHz and 5GHz are dropping where before it was just 2.4GHz?
Have you had any further drops since enabling Smart Connect again?
Yes.  It is bizarre.  It would seem the router is starting to just fail in general.  The router would always reboot but 5ghz devices would reconnect automatically and 2.4 would not.  Now both bandwidths will not automatically reconnect.   Again this failure to automatically reconnect to the network is not every time, but does seem to be increasing in frequency.
yes.  My xr500 rebooted at 12:04 last night and I had no devices connected as of a few minutes ago do about 6 hours.  So nothing reconnected all night (I can see connection logs on those devices).   Performed a manual reboot via a power disconnection and I am back to normal.
This XR500 is going on 4 plus years.   I am wondering if it’s time to just scrap it.  I just someone had a 700 in stock for a reasonable price!
OK, you say these drops started a few weeks ago, did these just start out of nowhere or was there any configuration changes or changes to the environment? Seems strange that it would just start out of nowhere.
I added a LAN device, a power line adapter, about a 3 weeks ago  I was having the issue prior though.    I will try to disconnect the line adapter when not in use and see if that makes a difference.   Like I said it was happening before, but maybe it is making it worse?
Yeah I don't see why that would make a difference to be honest, disconnect it and see if the drops are any less frequent so we can rule it out though!
