Upgrade to 3.0.719 hangs Rapp is not loaded
Some_Dude
HI there,
I had issues with a tablet disconnecting after 22 at night, so Netflix didn't work and some apps not working on my smart TV.
I updated to 3.0.179 firmware and it hangs in the update.
Antivirus was disabled.
And now it says on Netduma login after a while
"This Rapp is not loaded yet, please try again in a minute"
But now 15 minutes has gone since the upgrade started.
I got internet on the Netduma router.
What do I do? Wait it out or cut the power?
It seems like the upgrade process is stuck.
Windows 10 pro.
First try clearing your browser cache/cookies then refresh the page and make sure you're definitely connected to the router and you weren't disconnected and the PC connected to another WiFi network.
The process hung, so after 5 hours i cut the power. But then it wouldn´t recognise the login. And it was the correct ones.
So i reset the router reverting back to original firmware.
And tried it this morning without any problems.
After about 2 minutes the login popped up and now it´s 3.0.179 firmware.
Are you still having issues with the login? What credentials are you trying?
