Tejjo Posted December 16, 2020 Posted December 16, 2020 Hello Everyone, I am facing wired problem with my XR500 modem, I am trying to set up a local NAS by connecting external storage to the router (via USB). After basic configuration and creating a network share, the windows machine cant hold the network drive constantly gets disconnected and can't reconnect. Even the network speed is terrible the data breaks and fails to copy. I initially thought that the problem is with my external storage so swapped with a brand new one (SSD Drive), but still the same problem. Any help is much appreciated. Thank you
Netduma Liam Posted December 16, 2020 Posted December 16, 2020 Hi Tejjo, How are you configuring this? Using Readyshare within the XR500s config? Could you share a screenshot of your current configuration if possible?
iresolver Posted August 16, 2023 Posted August 16, 2023 I have the same problem I will post here if I fix the problem any help would be appreciated!
Administrators Netduma Fraser Posted August 17, 2023 Administrators Posted August 17, 2023 21 hours ago, iresolver said: I have the same problem I will post here if I fix the problem any help would be appreciated! Could you provide some more information about what you have tried?
Krush Posted August 18, 2023 Posted August 18, 2023 If you are on windows 11 or "10 to verify", the smb1 is not activated by default, which can cause problems. Type in the search bar of the taskbar "activate or deactivate windows features. Check the client smb1 / applied and restarted the PC! Netduma Fraser and Proud R3 Owner 2
