scoobypreza Posted November 4, 2020 Posted November 4, 2020 Hi using the new firmware and the wifi slows down over 2 days have to reboot the r2 to get the speed back any one else having this problem
Administrators Netduma Fraser Posted November 4, 2020 Administrators Posted November 4, 2020 What speeds does it start with and what does it decrease to?
scoobypreza Posted November 4, 2020 Author Posted November 4, 2020 Starts at 70/19 goes down to 30/12 is the lowest i have seen before I power cycle the r2
Administrators Netduma Fraser Posted November 4, 2020 Administrators Posted November 4, 2020 Is that on 5GHz close to the router?
Neroxnex Posted November 4, 2020 Posted November 4, 2020 I'm having this issue too. I'm on the latest public firmware version. Wifi works good for ~48 - ~72 hours then it starts to slow down to the point of which a reboot is required, which usually then fixes the issue for the next few days.
scoobypreza Posted November 4, 2020 Author Posted November 4, 2020 36 minutes ago, Netduma Fraser said: Is that on 5GHz close to the router? Yes m8 1m away and 5Ghz is still unusable upstairs 2.4Ggz iis very slow upstairs and no WiFi in my garden 3m away from the r2 with wall in the way
Administrators Netduma Fraser Posted November 4, 2020 Administrators Posted November 4, 2020 Thank you very much for the information, we will continue to improve upon WiFi but I'll create a new ticket for this specifically. I assume all wired devices keep the same speeds throughout?
Administrators Netduma Fraser Posted November 4, 2020 Administrators Posted November 4, 2020 Thanks for clarifying, I've made an internal ticket.
