need some help
lukasz
So i have gone through all the forum topicks and i have read all the small articles all of you guys make super stuff grate job. Bot i am still confuse about some stuff. So before i go in to it here is my exact setup ISP virgin media uk 100 mb down bot only around 6 mb up. Virgin superhub in to modem mode then conected to R1. My ps4 isthen connected by wire to R1 then wirelessly my gfiphone5 she usually watch youtube facebook and some www. Same thing goes to my frends pc he does exsacly what my gf i phone plus he may watch some porn. Now its my phone and while i am gamingi dont use it. So that is my setup and i dont know few things:
1. I have read that whit 100 mb download i should use only reactive algorithm and i did use both and is it possible that with my connection i can have better games using preemtive or i should always use reactive.
2. I can find my optimum settings like i mention before the next thing is the %on bandwhit and divice prioritization so knowing exactly my circumstances can some one help get max from this peac of equipment.
3. Since update 6 i can see the host or more likle it disappears when the game is starting when before i updated to 6 i could always see who is the host and there for i could see my ping.
4.what is the dormat serv and why i dont connect to them
And the picture attached is some kind of filter on coax that goes to my virgin super hub form the fiber boxx outside of the house guy who have put this sad it isa filter that makes only good singnals go to router so i will never have to reboot my router those are hes exact words
1. Reactive will likely always give you the best results, for gaming and general usage.  Based on your usage you are likely to never reach your maximum throughput.
2. To setup the device prioritization, simply drag your PS4 out to be a higher number than the other devices.  It sounds like all other devices can remain even.
3. This is definitely interesting, I haven't tested today (gaming) i've been busy with WiFi testing and configuration.  Someone else can speak to this if I don't test tomorrow.
4. post-168-0-61307300-1420365496_thumb.png Is this what you are speaking about? If so those are connections that aren't sending traffic to you anymore, but did once.  They should go away after a short period of time.
5. The Filter is to filter out signals that are out of range and some noise.  These are good in general, if the technician put it there I imagine he tested your line and decided you needed it for signal quality.
However, it doesn't have anything to do with the router side of things...it is actually all to do with the modem part of things.
4. attachicon.gifScreen Shot 2015-01-04 at 4.57.46 AM.png Is this what you are speaking about? If so those are connections that aren't sending traffic to you anymore, but did once.  They should go away after a short period of time.
what about the % on upand down lodas in my case
Guest Netduma_Iain
Agree with everything abc said. When you don't see the host its because you're on a dedicated server, in the next version we will show them.
For the up/down percentage I'd recommend keeping it 100% unless you're gaming. If you're gaming I personally like to set it to 70%.
Agree with everything abc said. When you don't see the host its because you're on a dedicated server, in the next version we will show them.p
so after the update i play only on dedicated servers becouse i am using strickt mode? So if i disable strickt mode mabye i can play more on players hosts?
Guest Netduma_Iain
No you were probably playing on them before as well. I would recommend you keep strict mode on but use the snap button if you aren't getting games.
no no i have no problems geting games this is Good like i sad i just dont know if i connect to a good host
Guest Netduma_Iain
Yes strict mode will get you the best hosts possible
to test simply turn geo-filter off and make sure your nat type is open.
Shure i think i am just a bad cod player first few days whit r1 i had a briliant fun i tested it on aw and ghost bot since i upgraded i am just getting owned again like i woes just plaibg fre for all and the guy whit ball 27 woes way faster iaming at me when i had asm1 with qiuckdraw grip i tested at ghost and alsou i woes destroed i gues i am just a bad cod player
I watch all the kill cams me and that other people run at each other and i have no chance the seems to be a chead of me again i fell like i have no chance i gun fight bot again i probobly suck at this game
Guest Netduma_Iain
Wait a few days as well mate, because xbl and PSN have been experiencing issues in the last few days
do you know anybody experiencing this or is just me becouse todays gaming session fellt like when i didnt have netduma
Guest Netduma_Iain
I think everyone is experiencing it. Have you got strict mode on right? Can you screenshot what your geo-filter please
Doesn't it seem like every time double XP is activated it causes more problems?!
this is screen shoot
Guest Netduma Fraser
I seem to remember I have had that before but then being fine without doing anything like a few days later. I could be wrong but I think if you wait a few days to let the XBL/PSN issues die down it may be alright.
could you tell me more specifically what you had before
I think I had the boxes and small circles like yours, I was searching for a game but couldn't find anything. Occasionally the small circles would go big but then small again until I gave up searching. Like I said this was a while ago so Im a bit fuzzy on the details.
well i can find games thats not the issue bot for like 2 days now game fells like before i hada nedduma obe step behin
I would definitely advise waiting for psn/xbl issues to go away and if in a few days its still an issue for you we can look further into it.
I've thought the same thing for years.  When double XP is active the game definitely plays worse.  As soon as they turn it off - back to normal.
i dont see on my account any double xp
it's active, but only giving double xp in the Moshpit playlist.   Xbox live is also having issues.  If you look at the Xbox status page, Social and Gaming is limited.
yes Xbox live is having issues but not on X1 (?) i have the same here lukasz
