Chaiyoabc Posted September 3, 2020 Posted September 3, 2020 I tested by lower sliders all the way to 1%. Which should be around 3.8/3.4 mbps right? When I go to the speedtest and fast. here is result Also when I use port checker tool, it says my port is closed
Chaiyoabc Posted September 3, 2020 Author Posted September 3, 2020 @Netduma FraserI think I might need factory version firmware of this. because this firmware is soo buggy
Kendal Posted September 3, 2020 Posted September 3, 2020 @Chaiyoabc Stupid question .. did you do a reset after the update? If not, I recommend it to you. You can search for the firmware in the forum https://forum.netduma.com/forum/106-latest-firmwares/ or here direct download: https://www.dropbox.com/s/bqk0zy5fg9tssq3/DumaOS-R2-3.0.123-Release.sig?dl=0
Administrators Netduma Fraser Posted September 3, 2020 Administrators Posted September 3, 2020 Which firmware are you using? Are you on PPPoE, IPv6 or using DHCP Identifiers? Is QoS completely disabled in the Congestion Control 3 line option menu? What settings do you have for Traffic Prioritization?
Chaiyoabc Posted September 3, 2020 Author Posted September 3, 2020 2 hours ago, Kendal said: @Chaiyoabc Stupid question .. did you do a reset after the update? If not, I recommend it to you. You can search for the firmware in the forum https://forum.netduma.com/forum/106-latest-firmwares/ or here direct download: https://www.dropbox.com/s/bqk0zy5fg9tssq3/DumaOS-R2-3.0.123-Release.sig?dl=0 cheers, I didnt look into that section, Stupid me! 41 minutes ago, Netduma Fraser said: Which firmware are you using? Are you on PPPoE, IPv6 or using DHCP Identifiers? Is QoS completely disabled in the Congestion Control 3 line option menu? What settings do you have for Traffic Prioritization? I'm using DHCP (DMZ from main router) Qos is enabled. I have been using this setting with no issue for few days. suddently when I switch my port prioritized device from ps4 to pc, it bugged
Administrators Netduma Fraser Posted September 3, 2020 Administrators Posted September 3, 2020 What is the Traffic Prioritization rule you have for the PC?
Chaiyoabc Posted September 3, 2020 Author Posted September 3, 2020 22 minutes ago, Netduma Fraser said: What is the Traffic Prioritization rule you have for the PC? manual (1:65535) udp and tcp
Administrators Netduma Fraser Posted September 3, 2020 Administrators Posted September 3, 2020 39 minutes ago, Chaiyoabc said: manual (1:65535) udp and tcp Is that destination & source? If so that is why. Traffic Prioritization supercedes Congestion Control to put the packets at the front of the queue - usually this isn't an issue as it's just used for gaming which requires very little bandwidth. Use the Games Console service instead to prioritize the games and redo the speed test and it will adhere to your Congestion Control settings.
Chaiyoabc Posted September 4, 2020 Author Posted September 4, 2020 Nvm, i got it working now. Just mess something in my asus router
