liveandletdie34 Posted August 15, 2020 Posted August 15, 2020 Hi for some reason I get about half of my speed from a wired connection. And full from WiFi. I am a little confused about this. Any idea to why thanks in advance
Administrators Netduma Fraser Posted August 15, 2020 Administrators Posted August 15, 2020 What are your expected/paid for speeds? Are they entered into the Congestion Control bandwidth settings? Are you using QoS? Post a screenshot of your Device Manager in table view showing the link speeds of the ports please.
liveandletdie34 Posted August 15, 2020 Author Posted August 15, 2020 12 hours ago, Netduma Fraser said: What are your expected/paid for speeds? Are they entered into the Congestion Control bandwidth settings? Are you using QoS? Post a screenshot of your Device Manager in table view showing the link speeds of the ports please. All of the above yes I have. And sorry didn’t know how to screen shot on my pc got a picture on my phone if that will do
liveandletdie34 Posted August 15, 2020 Author Posted August 15, 2020 2 minutes ago, liveandletdie34 said: All of the above yes I have. And sorry didn’t know how to screen shot on my pc got a picture on my phone if that will do Sorry I pay for 200 down and 20 up and that’s what I get we’ll just over
Administrators Netduma Fraser Posted August 16, 2020 Administrators Posted August 16, 2020 Thanks for that, so the router itself will get full speeds, that's why your WiFi is good. Out of the 4 LAN ports, 1 isn't being used, 1 is limited to 10Mbps, 1 is limited to 100Mbps and the other is full speed. So you need at least two Cat5e ethernet cable to replace those two as otherwise you won't get your full speeds out of them.
Guest Killhippie Posted August 16, 2020 Posted August 16, 2020 is PS4 Pro only on 10Mbps just trying to work out the devices from your list. I would get Cat 6 myself as they block more RFI. Cat 7 etc is over the top. Cat 6E would work fine but its penny's to get the better Cat 6 cables these days.
liveandletdie34 Posted August 16, 2020 Author Posted August 16, 2020 2 hours ago, Netduma Fraser said: Thanks for that, so the router itself will get full speeds, that's why your WiFi is good. Out of the 4 LAN ports, 1 isn't being used, 1 is limited to 10Mbps, 1 is limited to 100Mbps and the other is full speed. So you need at least two Cat5e ethernet cable to replace those two as otherwise you won't get your full speeds out of them. Cheers I was sure all my cables were cat5e as I make them my self of a coil
liveandletdie34 Posted August 16, 2020 Author Posted August 16, 2020 1 hour ago, Killhippie said: is PS4 Pro only on 10Mbps just trying to work out the devices from your list. I would get Cat 6 myself as they block more RFI. Cat 7 etc is over the top. Cat 6E would work fine but its penny's to get the better Cat 6 cables these days. PS4 is in port1 xbox port 2 my pc port 3 hive hub port 4
liveandletdie34 Posted August 16, 2020 Author Posted August 16, 2020 I have sorted the issue a faulty wire by looks of things or it was me when I have made it. Many thanks
