daz Posted August 14, 2020 Posted August 14, 2020 when i first set it up the wifi speed was basically the same as the ethernet speeds but now its incredibly slow and im getting about 5mb within about 2 meters of the r2 down to 1 or none in other parts of the house and regarding ping my ping under load is 200ms for the upload is there anything i can do to fix this?
Administrators Netduma Fraser Posted August 14, 2020 Administrators Posted August 14, 2020 The next update will improve on WiFi performance. If you reboot the router do the speeds return? For ping under load use QoS to limit that as much as possible.
daz Posted August 14, 2020 Author Posted August 14, 2020 8 minutes ago, Netduma Fraser said: The next update will improve on WiFi performance. If you reboot the router do the speeds return? For ping under load use QoS to limit that as much as possible. what has lowered my speeds tho?
Administrators Netduma Fraser Posted August 14, 2020 Administrators Posted August 14, 2020 Hard to say, could be wireless contention. What speeds do you get through ethernet at the moment?
daz Posted August 14, 2020 Author Posted August 14, 2020 7 minutes ago, Netduma Fraser said: Hard to say, could be wireless contention. What speeds do you get through ethernet at the moment? when i run connection test i get 25 down and 6 up which is also down from 35 down, when i do speedtest on ookla im getting 2 down whats going on?
Administrators Netduma Fraser Posted August 14, 2020 Administrators Posted August 14, 2020 Have you changed any settings at all prior to these speed drops?
daz Posted August 14, 2020 Author Posted August 14, 2020 4 minutes ago, Netduma Fraser said: Have you changed any settings at all prior to these speed drops? None, did a quick initial set up and left it at that, haven't had time to play around with it tbh
Administrators Netduma Fraser Posted August 15, 2020 Administrators Posted August 15, 2020 16 hours ago, daz said: None, did a quick initial set up and left it at that, haven't had time to play around with it tbh I've sent you a PM.
CRarsenxL Posted August 22, 2020 Posted August 22, 2020 I too have not touched any settings but randomly in cod I’ll check ping plotter my ping is like much higher than usual , my WiFi stops loading/slow and my in game ping is higher for a few seconds
Administrators Netduma Fraser Posted August 22, 2020 Administrators Posted August 22, 2020 6 hours ago, fiefo said: I too have not touched any settings but randomly in cod I’ll check ping plotter my ping is like much higher than usual , my WiFi stops loading/slow and my in game ping is higher for a few seconds Could you expand on these points, how much higher is the ping on PingPlotter and the game? Regarding WiFi do you mean you can't load websites slow or speedtest reports slow speeds?
CRarsenxL Posted August 22, 2020 Posted August 22, 2020 Significantly. My base is usually 17-20. After a few minutes past, it was at 50-60. In game, I was getting spikes, so base ping would be 40 on a east coast goat aka my friend. But randomly it will lag and I’ll look at the in game ping and it’ll be 100
Administrators Netduma Fraser Posted August 22, 2020 Administrators Posted August 22, 2020 Are you playing via WiFi then? What QoS settings are you using? What are your Ping Under Load results?
CRarsenxL Posted August 23, 2020 Posted August 23, 2020 Wired. No CC. No Bandwidth allocation. Just traffic prio. Ping under load is around 13.8 but ping plotter has spikes very high at random times. Never saw that before with the XR300
Administrators Netduma Fraser Posted August 23, 2020 Administrators Posted August 23, 2020 You need to use Congestion Control to eliminate lag more effectively, start with 70% each and adjust if needed to eliminate the lag.
