Help bandwith
Cocoon992
Hello,
So i have a ps4 upstairs and my modem is downstairs. They are connected with powerline adapters because i can’t place a cable because it’s not my house. So my modem is connected with the netduma r1 and that one is connected to the powerline.
so i recently factory reset my R1 and i wanted to fill in the bandwith for the QOS. So i connected my R1 to my laptop with cable and went to speedtest.net. The results are download 5,35 and upload 7,43. Should i enter these in the bandwith and then set sliders to 70/70?
Ok so do i need to go lower or higher with the sliders to find the best hit detection?
If you're wanting to optimize the percentage then I would suggest trying both higher and lower than 70%. Every connection is different so it may not always be that lower is better.
