fliptemprr Posted December 9, 2019 Posted December 9, 2019 so every time i reset my router or it looses power it just says on my wifi connected, no internet accses, and theres no internett on my other devices
Administrators Netduma Alex Posted December 10, 2019 Administrators Posted December 10, 2019 Sounds like it's losing it's connection to the modem. In the Network Settings > WAN panel, have you set up Static IP or anything? If so, this may be causing issues.
fliptemprr Posted December 10, 2019 Author Posted December 10, 2019 33 minutes ago, Netduma Alex said: Sounds like it's losing it's connection to the modem. In the Network Settings > WAN panel, have you set up Static IP or anything? If so, this may be causing issues. What's static tho?
DanyKTM Posted December 10, 2019 Posted December 10, 2019 Static IP is your own address that you manually assigned to your netgear modem.
fliptemprr Posted December 10, 2019 Author Posted December 10, 2019 41 minutes ago, DanyKTM said: Static IP is your own address that you manually assigned to your netgear modem. Do i just pick a random one or like my PC or sth like that
DanyKTM Posted December 10, 2019 Posted December 10, 2019 go to setting, network and select ip static, see below, it is not my set, its picture I found on Internet
Administrators Netduma Alex Posted December 10, 2019 Administrators Posted December 10, 2019 1 hour ago, fliptemprr said: Do i just pick a random one or like my PC or sth like that If you're setting a static IP for your WAN connection, you should probably go to System Information and copy the WAN IP that's listed there, then put that in as your static IP. Subnet mask should be 255.255.255.0 Gateway IP should be the address of your modem... It's probably the same as your WAN IP but the number after the third dot is 1 If you want to set manual DNS, i'd do 8.8.8.8 and 8.8.4.4 - the third one can be your gateway IP again
