Ping assit help
Blameless
So with Auto Ping enabled if you disable Ping Assist, Auto Ping appears and shows you the ping but if Ping Assist is higher than 0 then Auto Ping won't show you the ping? Does the Auto Ping panel appear just without the ping?
Yes everytime I enable ping assist let's say 45ms my ping bar doesnt show so I dont if I'm playing on the ping or higher? One question when are you guys going to update your cluod for MW???
That's very interesting, I'll have to get Alex to test that as it could be the cause of the ping issue. Alex is currently working on that, although is having some trouble but hoping that won't take too long to resolve.
I'll try to duplicate the problem again if it happens again then I'll get back to you!
Hope fully because I keep connecting to peer instead of dedicated servers!! Which I live in L.A
That'll just be incorrect classifications - you're likely connecting to dedicated servers that are just displayed as peers. That's something we're working on fixing, but it won't impact your game performance :)
