I need help setting up VPN Dedicated IP
stvbdkd
Hey I need some help with connecting my PS4 to PureVPN I have the dedicated ip address I have try to put the hostname into the advanced settings config but that just gave me an error can anybody help me.
So you're trying to use Hybrid VPN with your PS4? You should just have to do the following:
  • Copy the OpenVPN file into the Advanced tab of Hybrid VPN
  • Once the VPN is added, add your PS4 using the window to the right
  • Once the PS4 is added, it will be greyed out, this is NORMAL because all traffic for games consoles is automatically included
39 minutes ago, stvbdkd said:
thanks what about if I have my own dedicated ip and server through pureVPN sorry for the confuse.
I assume you can remote the address on the remote line and replace it with yours, otherwise I would suggest you open a ticket with PureVPN
