bigtuna619 Posted May 31, 2019 Posted May 31, 2019 can't connect to the ea server at all. I did followed the steps y'all show us did not working. please help. also, if i get into a game, once we done with that match, i get disconnected back to the ea server.
Administrators Netduma Alex Posted May 31, 2019 Administrators Posted May 31, 2019 Are you trying to play with the Geo-Filter enabled? Did you set it up as shown in this guide? http://support.netduma.com/en/support/solutions/articles/16000077072-dumaos-optimal-settings-guide-geo-filter Have you pressed FLUSH CLOUD on the Geo-Filter recently? We updated the cloud yesterday so it's worth doing. And are you using the latest version of DumaOS? Just checking because compatibility with Apex can't be guaranteed with an older version.
Unknown Posted May 31, 2019 Posted May 31, 2019 any point in using the geo filter it puts you on the closest server to you on apex and does the same on most games
Administrators Netduma Alex Posted May 31, 2019 Administrators Posted May 31, 2019 True, but the Geo-Filter can block you from being put into any games you don't want to be in. For example maybe you'd be put into a non-ideal game to balance the teams, Geo-Filter could prevent that. You could also use it to connect to games in your home country if you moved away, although you'd have high ping naturally. Some games are better than others at putting you in a good server. If the game sucks at it, Geo-Filter could salvage it.
bigtuna619 Posted June 1, 2019 Author Posted June 1, 2019 i did all this and still saying... can't connect to ea server and also saying attempting 1 out 9. even if i get lucky and play one game, after the one match ended, why do i get disconnected out of the ea server? i also flush the cloud so many times.
bigtuna619 Posted June 1, 2019 Author Posted June 1, 2019 can't connect to ea server code 200. this gotta be the worse 500 bucks i paid for. 5 days now.
Administrators Netduma Fraser Posted June 1, 2019 Administrators Posted June 1, 2019 Are you getting anything blocked on the Geo-Filter when you get that message? Based on your screenshot from the other topic your Geo-Filter settings are fine, no need to select a profile.
