PharmDawgg Posted July 3, 2015 Posted July 3, 2015 I keep getting an error message with VPN. Config file if below. For some reason I can not copy the VPN log. client dev tun proto tcp remote atl-a01.ipvanish.com 443 resolv-retry infinite nobind persist-key persist-tun persist-remote-ip ca ca.ipvanish.com.crt tls-remote atl-a01.ipvanish.com auth-user-pass comp-lzo verb 3 auth SHA256 cipher AES-256-CBC keysize 256 tls-cipher TLS-DHE-RSA-WITH-AES-256-CBC-SHA:TLS-DHE-DSS-WITH-AES-256-CBC-SHA <ca> -----BEGIN CERTIFICATE----- MIIErTCCA5WgAwIBAgIJAMYKzSS8uPKDMA0GCSqGSIb3DQEBBQUAMIGVMQswCQYD VQQGEwJVUzELMAkGA1UECBMCRkwxFDASBgNVBAcTC1dpbnRlciBQYXJrMREwDwYD VQQKEwhJUFZhbmlzaDEVMBMGA1UECxMMSVBWYW5pc2ggVlBOMRQwEgYDVQQDEwtJ UFZhbmlzaCBDQTEjMCEGCSqGSIb3DQEJARYUc3VwcG9ydEBpcHZhbmlzaC5jb20w HhcNMTIwMTExMTkzMjIwWhcNMTcwMTEwMTkzMjIwWjCBlTELMAkGA1UEBhMCVVMx CzAJBgNVBAgTAkZMMRQwEgYDVQQHEwtXaW50ZXIgUGFyazERMA8GA1UEChMISVBW YW5pc2gxFTATBgNVBAsTDElQVmFuaXNoIFZQTjEUMBIGA1UEAxMLSVBWYW5pc2gg Q0ExIzAhBgkqhkiG9w0BCQEWFHN1cHBvcnRAaXB2YW5pc2guY29tMIIBIjANBgkq hkiG9w0BAQEFAAOCAQ8AMIIBCgKCAQEAt9DBWNr/IKOuY3TmDP5x7vYZR0DGxLbX U8TyAzBbjUtFFMbhxlHiXVQrZHmgzih94x7BgXM7tWpmMKYVb+gNaqMdWE680Qm3 nOwmhy/dulXDkEHAwD05i/iTx4ZaUdtV2vsKBxRg1vdC4AEiwD7bqV4HOi13xcG9 71aQ55Mj1KeCdA0aNvpat1LWx2jjWxsfI8s2Lv5Fkoi1HO1+vTnnaEsJZrBgAkLX pItqP29Lik3/OBIvkBIxlKrhiVPixE5qNiD+eSPirsmROvsyIonoJtuY4Dw5K6pc NlKyYiwo1IOFYU3YxffwFJk+bSW4WVBhsdf5dGxq/uOHmuz5gdwxCwIDAQABo4H9 MIH6MB0GA1UdDgQWBBRL/RQliR3nwXCD1/afERwlThnurjCBygYDVR0jBIHCMIG/ gBRL/RQliR3nwXCD1/afERwlThnurqGBm6SBmDCBlTELMAkGA1UEBhMCVVMxCzAJ BgNVBAgTAkZMMRQwEgYDVQQHEwtXaW50ZXIgUGFyazERMA8GA1UEChMISVBWYW5p c2gxFTATBgNVBAsTDElQVmFuaXNoIFZQTjEUMBIGA1UEAxMLSVBWYW5pc2ggQ0Ex IzAhBgkqhkiG9w0BCQEWFHN1cHBvcnRAaXB2YW5pc2guY29tggkAxgrNJLy48oMw DAYDVR0TBAUwAwEB/zANBgkqhkiG9w0BAQUFAAOCAQEAho5ynpvtXISz3neqGXpL BBlOM35pd1ZSNHLCb2yHQwAjZbfYqfX2MDs9ytH4Cf1OfaVqwe777QyyIC2XR2QK kw4c2hCT8wPzWhmkLx8Q+jnKdOKkdz+L8+Ji9/vjtaFOcYjMDalI6CbjBiuMFWhB IzOaYljmA2UeQCVIz9aW80BC8+sLQ6oeWVnFjx7zqK1gbbc2bNuy3slOMdyoEj2m hkxfiffuHKV+GQoR7tFIr3M7KFFwYgkXeyLh1Pc0rZu7dGe4fUAbR1okB1DgelBd n6rWTZ8XcNzT/YngtH4bXB9DM7pKWpDWc94va4hFrGgaOxjE861TdoDqHaMO9bW+ Pg== -----END CERTIFICATE----- </ca>
Netduma Staff Netduma Crossy Posted July 3, 2015 Netduma Staff Posted July 3, 2015 I think it's because of the line that says 'ca ca.ipvanish.com.crt'. Try deleting that line and see if it works then
Administrators Netduma Fraser Posted July 3, 2015 Administrators Posted July 3, 2015 Let us know if Crossys answer resolves it
PharmDawgg Posted July 3, 2015 Author Posted July 3, 2015 I deleted the line from the config file but it does not save it.
Netduma Staff Netduma Crossy Posted July 3, 2015 Netduma Staff Posted July 3, 2015 I deleted the line from the config file but it does not save it. Disable the VPN, change the line then enable the VPN and see if it saves
PharmDawgg Posted July 3, 2015 Author Posted July 3, 2015 It did not save. I really do not want to factory restore. I am on an Imac and it is hardwired to the router. Everything else is working perfectly.
Netduma Staff Netduma Crossy Posted July 3, 2015 Netduma Staff Posted July 3, 2015 Did you disable the VPN first by unticking the box and clicking apply?
PharmDawgg Posted July 3, 2015 Author Posted July 3, 2015 Yes sir. It's almost like only in the VPN section it is not responding to my inputs. But everywhere else on the router it is. And I even tried a different web browser. Mozilla.
Netduma Staff Netduma Crossy Posted July 3, 2015 Netduma Staff Posted July 3, 2015 Could you try just restarting the router?
PharmDawgg Posted July 3, 2015 Author Posted July 3, 2015 Actually I did a few times. I was actually thinking about just waiting until they put out the new update and maybe when I install the update it will fix this. Because I am not currently really using the VPN that much and everything else is working perfectly. And I really do not want to restore to factory settings because I have so many devices that it would kind of be a pain to reenter all of them. LOL.
Administrators Netduma Fraser Posted July 3, 2015 Administrators Posted July 3, 2015 Is there anything you really need it for? Unticking all the devices then changing it and then reticking the devices should work
PharmDawgg Posted July 3, 2015 Author Posted July 3, 2015 No not really. I don't have any devices ticked. I have actually cancelled my subscription. It stops at the end of the month.
Administrators Netduma Fraser Posted July 3, 2015 Administrators Posted July 3, 2015 Ahh fair enough man, well I'll keep this issue in mind and see what we can do, I'm sure theres an easy solution!
PharmDawgg Posted July 3, 2015 Author Posted July 3, 2015 Thanks sir. I really appreciate all you guys do.
Administrators Netduma Fraser Posted July 3, 2015 Administrators Posted July 3, 2015 Thanks sir. I really appreciate all you guys do. Thanks Buck, we really appreciate everyones support
PharmDawgg Posted July 4, 2015 Author Posted July 4, 2015 I went ahead and did a factory reset from the GUI and it fixed the VPN issue. Something must have gotten glitched or something. Because I forgot to mention and I did not realize it at the time but when I rebooted the router it I did not hear the beep. So I unplugged the router and waited a few minutes. After that the beep came back as well. So now everything is OK.
W11cE Posted July 4, 2015 Posted July 4, 2015 I got those beepless reboots also when i was tinkering with vpn settings. Related to vpn? i dont know, maybe coincidence. What i noticed was that i couldnt get the connection working with R1 set to DMZ on modem. Had to disable routing on modem completely to get it working.
Administrators Netduma Iain Posted July 4, 2015 Administrators Posted July 4, 2015 Hi guys Fraser is away at an event, so I'm jumping to this thread late. Is everything resolved? If not I'll be available tomorrow to assist with any VPN stuff you need
PharmDawgg Posted July 4, 2015 Author Posted July 4, 2015 Iain everything is fine. I had to factory reset to fix. I kept getting the unable to communicate with the router.
Administrators Netduma Iain Posted July 4, 2015 Administrators Posted July 4, 2015 ok wicked mate I'll believe there is a ticket about the VPN being coupled with the cloud. I'll be looking into that in future updates.
