help host filtering for fortnite
bernhard
hello i am sort of new here and i am trying to figure out how to setup the host filtering for my pc for the game fortnite i am not new to using the netduma r1 router but i just cant seem to figure out what port number to input for the host filter... if anyone could help i would be grateful i am extremely sorry if this is in the wrong forum section too by the way i just didn't know where to put it so i figured gaming would be a start.... thank you everyone in advance for your time :)
Fortnite does not work on geo filtering as it allows you to select servers from inside the game. It works for games such as call of duty where it is not possible to do that in their games.
Hi - please could you upgrade to DumaOS: https://netduma.com/r1-dumaos/
After upgrading, do this to show Fortnite on your Geo-Filter:
1. Delete any devices from your Geo-filter
2. Go to the Device Manager
3. Click on your PC
4. Change the PC device type to a PS4 device type
5. Save your changes
6 Go back to the Geo-Filter and re-add your PC at the top
I recommend you use the Geo-Filter in Spectating Mode, and look at the Map when you join a lobby to see where the server is located. Then back out of lobby if it's the server region you don't like.
