Udnp help please
kinel
I am wandering how you set up these upnp listed ports ,   too port forwardinging and  traffic correctly
In upnp  its listed like this
Description         internal port               external port              protocol
Pcp map              6672                              1026                              udp
In portforward and traffic priortization its listed like this
Portforward
  Name                  source                           destination              protocol
In traficc priortization  its listed like this
                                  Source                         destination             protocol
                                   Start                            end
                                    Start                           end
So please can you tell me how i would set up the ports listed in the upnp list to be  port forwarding and traffic priortization
As these are the ports rdr2 onile uses these and a few more as it shows these in my
You don't need to do this for Traffic Prioritization as DumaOS Classified Games will prioritize the ports that the game uses and if UPnP is opening the ports correctly as well then there is no need to Port Forward.
We don't recommend change the source ports unless you definitely know what they are as it could impact your game experience. So for Traffic Prio leave the source as 1-65535.
For Port Forwarding just add the ports for the game as normal
So would i put in portforward
6672             1026                        udp
Is that the right way to do the ports i listed at the top of this thread
As those are the one that it shows me when i play red dead online
Heres how it shows it  in upnp
Does internal  mean  source  and
External  mean destination
Because there all worded diffrently thats why im cofused
 Cheers again for you help
