fakkel Posted November 18, 2018 Posted November 18, 2018 I have received a new IP from my VPN I changed my old ip for the new one in my config file and I clicked connect on the NetdumaR1, it then says connecting, connected and then 30 seconds later is says failed and all the settings disappeared! I seem to fix it to change the remote port from 443 to 80, only issue I am facing now, that even though the VPN works my settings in advance are invisible/disappeared. VPN works no input settings to be seen.
Administrators Netduma Fraser Posted November 18, 2018 Administrators Posted November 18, 2018 Okay that's a weird one, it's more likely to be a browser issue. What browser are you using to view the interface and do this?
fakkel Posted November 19, 2018 Author Posted November 19, 2018 I use Google Chrome - Windows 10 64bit Pro - Settings are still not visible 24hours later and that is a little bit annoying I have to change just a small thing. By the way this started happening when adding a brand new IP, I don't want to mention the IP range here but maybe that can solve some issues, because when entering those specific IP ranges, the interface would say connecting, connected 30 seconds later fail and then wipe the entire config page including username and password.
Administrators Netduma Admin Posted November 20, 2018 Administrators Posted November 20, 2018 Hi Fakkel - we discovered the same bug in testing yesterday so we've raised a ticket and are looking into it. Thanks for letting us know.
