nunogsm Posted October 23, 2018 Posted October 23, 2018 Hello to all netduma fans. its possible low my ping? this is a picture of my test, i have vodafone 100up/100down , in this zone the service is a coaxial fibre , not optic fibre!!!
pollutionblues Posted October 23, 2018 Posted October 23, 2018 I would run a PingPlotter test directly from your modem, ping twitter.com for a minimum of 10 minutes and post the results. This will let you know if there are any issues with your line that could be causing your ping to be high.
nunogsm Posted October 23, 2018 Author Posted October 23, 2018 If i make a test in speedtest site, this are the resolts.
pollutionblues Posted October 24, 2018 Posted October 24, 2018 10 hours ago, nunogsm said: resolts That plot is perfect, no jitter at all! Your ping is high but you may live far away from the twitter servers, you could ping google and see what ping you get to their servers if you wanted. Personally, I would take a higher ping that is as stable as yours over a low ping that is unstable.
nunogsm Posted October 24, 2018 Author Posted October 24, 2018 yes, e live about 500kilometers from de my internet server
Netduma Staff Netduma Jack Posted October 24, 2018 Netduma Staff Posted October 24, 2018 27 minutes ago, nunogsm said: yes, e live about 500kilometers from de my internet server I've never seen a pingplotter graph like that. That's insane. You could take off in a plane on that graph it's so flat. You must be pretty proud of it!
nunogsm Posted October 24, 2018 Author Posted October 24, 2018 14 minutes ago, Netduma Jack said: I've never seen a pingplotter graph like that. That's insane. You could take off in a plane on that graph it's so flat. You must be pretty proud of it! thanks
