Coyote305 Posted October 23, 2018 Posted October 23, 2018 My xfinity cable modem when I plug the hard wire to my xbox it shows in the network settings IPv4 & IPv6 but, when I plug the net Duma it only shows IPv4 only should I run what the modem is running
Urge Posted October 23, 2018 Posted October 23, 2018 Hi coyote, I'm pretty sure most people run at IPv4 so you should be okay if that's what you're getting.
pollutionblues Posted October 23, 2018 Posted October 23, 2018 48 minutes ago, Coyote305 said: My xfinity cable modem when I plug the hard wire to my xbox it shows in the network settings IPv4 & IPv6 but, when I plug the net Duma it only shows IPv4 only should I run what the modem is running Netduma recommend IPv4 as IPv6 can sometimes cause issues with QoS. IPv6 doesn’t offer any benefit to gaming either so best to stick with IPv4.
Netduma Staff Netduma Jack Posted October 24, 2018 Netduma Staff Posted October 24, 2018 16 hours ago, Coyote305 said: My xfinity cable modem when I plug the hard wire to my xbox it shows in the network settings IPv4 & IPv6 but, when I plug the net Duma it only shows IPv4 only should I run what the modem is running Hi, welcome to the forum! Pollutionblues is correct above. Don't fall for the marketing - IPv6 doesn't impact your gameplay in any way, it's one big placebo effect. Since the vast majority of home networks run on IPv4 you should use IPv4. If you want to prove for yourself that it doesn't affect your connection, just think about what it actually is. ISP's ran our of numbers to use for their IPv4 format, so they came up with IPv6 which changed the number format and allowed for more IP addresses to be created. That's it folks!
