ServerError Posted June 25, 2015 Posted June 25, 2015 Hello, The router freezes on reboot if I leave the cable plugged into the PoE (WAN) port. The router will only work again if I unplug the cable from the PoE port and then power cycle it by pulling the power cable. Is anyone else experiencing this? Running latest firmware. Thanks
Netduma Crossy Posted June 25, 2015 Posted June 25, 2015 Hi ServerError - welcome to the forums Why doesn't the router work? Does it just not boot up, can you not access the internet or can you now access the router dashboard?
lukasz Posted June 25, 2015 Posted June 25, 2015 Simple litle thing i found on wiki but wort to tried outThe R1 keeps restarting itself This is most likely an overheating issue. Make sure its not on a surface that will make it overheat. Also if possible get surge protection.
lukasz Posted June 25, 2015 Posted June 25, 2015 And also WElCOME TO THE DUMA ARMY buddy enjoy you self
Administrators Netduma Fraser Posted June 25, 2015 Administrators Posted June 25, 2015 Hey Server, welcome to the forum. What do you mean by freezing exactly? Does it just fail to boot so theres no lights or a beep? Overheating could be a concern as lukasz said. Edit - Please see here for most recent thread http://forum.netduma.com/topic/2783-router-freezes-on-reboot-with-cable-plugged-into-wan-poe-port/
