Chaiyoabc Posted July 1, 2018 Posted July 1, 2018 I had been aboard for ike 10 days. and when I come back home. and try to adjust my router lllike I do everytime I play a game, Netduma somehow acting weird loading up menu. It takes forever, to load one host fitering menu. I did reboot but still no lluck.
RL317 Posted July 1, 2018 Posted July 1, 2018 Are you using port forwarding? Enabling that and the geofilter simultaneously causes the GUI to slow down to a crawl on any firmware after 1.03.4. Sadly if you're on 1.03.6j you can't downgrade to try anything else so you'll either have to: A. Use UPnP instead of port forwarding B. Disable the geofilter C. Set the geofilter service to something like port 3074 (for CoD for example) rather than a preset like PSN/XBL, and deal with the geofilter no longer showing server dots (though the geofilter will still run correctly otherwise)
Administrators Netduma Admin Posted July 2, 2018 Administrators Posted July 2, 2018 Could you also try loading the interface in incognito mode on your browser? Sometimes your browser extensions can cause problems, so this is a good way to find out.
