indy56 Posted June 16, 2015 Posted June 16, 2015 Just followed the instructions i got with my Netduma , also tried the 192.168.88.1 with google chrome and firefox, nothing worked, so whats the deal here then, ??
Zennon Posted June 16, 2015 Posted June 16, 2015 Are you trying to connect via an Ethernet cable ?Here is the Netduma wiki on how to fully set up the router http://wiki.netduma.com/doku.php?id=start
indy56 Posted June 16, 2015 Author Posted June 16, 2015 I have tried putting in 192.168.88.1 using both google chrome and firefox but it keeps saying web page unavailable, plus i have to keep my desk top plugged into my sky hub, as soon as i remove it to put into the netduma i lose internet access, i am using a wired connection as the wireless is crap.and very slow.
Administrators Netduma Fraser Posted June 16, 2015 Administrators Posted June 16, 2015 So just to be clear, putting in the IP and it returning web page unavailable occurs when you are wired to the R1 and you have no internet? Please make sure thats the case and you are not trying to connect to the R1 when still connected to the Sky Hub as this would not work.
Zennon Posted June 16, 2015 Posted June 16, 2015 So you have turned off wifi on the skyhub and have an Ethernet cable going from the skyhub into the Netduma in poe port one then an Ethernet cable from the Netduma in any other port to your pc?
RADDY1993 Posted June 16, 2015 Posted June 16, 2015 Just followed the instructions i got with my Netduma , also tried the 192.168.88.1 with google chrome and firefox, nothing worked, so whats the deal here then, ?? Look at this http://forum.netduma.com/topic/2111-how-to-set-up-the-netduma-with-sky-fibre-sr-102-modemrouter/
