XR500 IPv6 problems
Hi guys,
I noticed when using IPv6 Native PPoEE, the network monitor doesn't work properly when displaying the (Mbps) from active devices - any solutions cheers
Hi guys,
Hi, welcome to the forum! So just to clarify this issue completely, in what way specifically does the Network Monitor not work properly? Which graphs are incorrectly displaying information?
If you could post a screenshot here for us to look at, that would be a fantastic help. Our lead tech guru Fraser will be online soon and will be able to pitch in with his thoughts, but until then any and all information you could share with us would help us greatly :)
Hi,
I'll upload the screenshots:
https://imgur.com/yiKx8GS
https://i.imgur.com/v510znL.png
The Bandwidth MBps is wrong should be like 5-10MBps not 0.01 and that - it resolves when I turn off IPv6
What are you doing on these devices when the screenshots were taken?
If you do something like a speed test does the network monitor not appear accordingly?
Yeah a speed test or general browsing for watching videos - it will not display the correct speed on both of the graphs - will only work if I disable IPv6
Okay just spoken with the Devs and they have informed me that the router functionality is there but advanced DumaOS features are currently IPv4 only. We are seeing more people starting to use IPv6 so it is something we'll be looking into.
Ah okay, didn't know IPv6 would cause that - ill disable it for now and continue using IPv4
Confirmed. I can produce the exact same issue.
Would recommend turning off IPv6 as it's not supported currently.
Great thanks, let us know how you get on!
Seems to working fine on IPv4 ! Really liking the router and the awesome OS support - only developers I've seen who are interested fixing bugs and making new features!
Great to hear that, thanks for the update! Thank you, we're really proud of our software and want to keep making it better and better!
