JACKSDARIPPER Posted February 25, 2018 Posted February 25, 2018 I got my netgear xr500 on Friday I hook it every was working fine up until today. I’m not getting my full speed when I was getting before. I rebooted my router and still is nothing.
Administrators Netduma Admin Posted February 25, 2018 Administrators Posted February 25, 2018 Hi Jack, It could be that your Internet provider is under serving you at the moment, which is especially common on a Sunday. But it could also be a router setting, so please do these steps to make sure they’re all ok: First set your bandwidth to your expected speeds in Anti-Bufferbloat advanced options Then set Anti-Bufferbloat to 'Never'. Reset distribution on Bandwidth Allocation for both download & upload. Also make sure share excess for both download & upload on Bandwidth Allocation are checked (also in advanced options) Then remove/disable any rules for Traffic Prioritization. Then for an accurate test make sure to do a wired speed test from a PC from speedtest.net (console tests are often inaccurate). If you don't get your full speeds after that then disable QoS completely within Anti-Bufferbloat's settings and try again. If after this your speeds are not full then it is almost certainly your Internet Provider.
JACKSDARIPPER Posted February 25, 2018 Author Posted February 25, 2018 Thank you . Now I’m getting my full speed.
Administrators Netduma Admin Posted February 25, 2018 Administrators Posted February 25, 2018 Great. I now recommend you setup QoS to activate when you are gaming, which will prevent congestion from causing you to lag. If you choose 'High Priority Traffic Detected' mode it will only activate when you are gaming, meaning your speeds are not reduced when you are not. The simplest way of learning about this, is to click the '?' symbol at the top next to the QoS title. This will take you on a tour of the page, explaining how each feature works. Let us know if you need help with anything else.
JACKSDARIPPER Posted February 25, 2018 Author Posted February 25, 2018 Also when I’m gaming should I have share excess un ticked
Administrators Netduma Admin Posted February 25, 2018 Administrators Posted February 25, 2018 We highly recommend you keep share excess ticked. This means that when your device does not need the bandwidth allocated to it, it will automatically give it to any device that does need it, so there really is no good reason to not keep it ticked.
JACKSDARIPPER Posted February 25, 2018 Author Posted February 25, 2018 Also my other problem is that I have to keep my WiFi on on my Verizon modem/ router because if I don’t my wife can’t use her app to see her tv show she recorded on the dvr or any ondamand shows
Administrators Netduma Admin Posted February 25, 2018 Administrators Posted February 25, 2018 Also my other problem is that I have to keep my WiFi on on my Verizon modem/ router because if I don’t my wife can’t use her app to see her tv show she recorded on the dvr or any ondamand shows Does it have to be connected to the modem, or can you just connect your smart TV to the XR500? There should be a network setting on your TV to do this. I recommend you do this because then she cannot cause you to lag when she watches an on demand show because of the XR500 QoS.
JACKSDARIPPER Posted February 25, 2018 Author Posted February 25, 2018 It’s to be connected to the Verizon Fios IP address the setup box
JACKSDARIPPER Posted February 25, 2018 Author Posted February 25, 2018 Well is the set top box from Verizon it needs the IP address and WiFi from Verizon
Administrators Netduma Admin Posted February 25, 2018 Administrators Posted February 25, 2018 Well is the set top box from Verizon it needs the IP address and WiFi from Verizon Ok, if it has to be connected to the Verizon box then so be it! Usually set top boxes are not that strict but maybe Verizon are different.
JACKSDARIPPER Posted February 26, 2018 Author Posted February 26, 2018 Another thing is no matter where I set my anti bufferbloat slider I don’t get a good connection
Administrators Netduma Admin Posted February 26, 2018 Administrators Posted February 26, 2018 Anti-Bufferbloat prevents lag from occurring when other devices on your network use all of your bandwidth. We recommend you set this to 70% for both download and upload, and set the mode to ‘High Priority Traffic Detected’. How are you measuring a good connection? And what game are you playing? If you are on a console game like CoD, make sure you have added your console to the Geo-Filter, as this will guarantee a local server I.e. the best connection possible.
JACKSDARIPPER Posted February 26, 2018 Author Posted February 26, 2018 Yes I’m playing on my ps4 so don’t use always use the high priority traffic detected
Administrators Netduma Admin Posted February 26, 2018 Administrators Posted February 26, 2018 Ok, we’ll please use this as it will automatically apply Anti-Bufferbloat when you play. Also make sure ‘DumaOS Classified games’ is checked in Traffic Prioritization. What games are you playing? This video explains why it’s important and how to set it up from 44:40 - https://www.youtube.com/watch?v=KQiwtXoNqsA
JACKSDARIPPER Posted February 27, 2018 Author Posted February 27, 2018 I noticed today from videos of the night hawk XR500 on YouTube that everyone else’s led lights are all white on the right side of the right where Ethernet 1,2 ,3 ,and 4 are the led lights are orange. How are they orange
Administrators Netduma Fraser Posted February 27, 2018 Administrators Posted February 27, 2018 I noticed today from videos of the night hawk XR500 on YouTube that everyone else’s led lights are all white on the right side of the right where Ethernet 1,2 ,3 ,and 4 are the led lights are orange. How are they orange If they're orange it means those ports are not getting internet or there is no data flowing through them at that time. Can also occur if you've just rebooted/factory reset will it's still booting up.
JACKSDARIPPER Posted February 27, 2018 Author Posted February 27, 2018 Well one of the ports I have my laptop and third port is my security cameras those are the one with the orange lights and the first port is my PS4 and the light on that one is white
Administrators Netduma Fraser Posted February 27, 2018 Administrators Posted February 27, 2018 Well one of the ports I have my laptop and third port is my security cameras those are the one with the orange lights and the first port is my PS4 and the light on that one is white As long as you're getting internet through the ethernet ports then it's nothing to worry about
JACKSDARIPPER Posted February 27, 2018 Author Posted February 27, 2018 I also noticed that when I had the PS4 connected to Ethernet port one on the back the Ethernet port 4 light indicated that was the PS4 how come if I have it connected to the one that’s says port one on the back
JACKSDARIPPER Posted February 27, 2018 Author Posted February 27, 2018 I also noticed that when I first connected the router I plug in all the Ethernet wires how they are number on that back of the router I plug in my ps4 to the first port but it indicates that it’s on the 4 Ethernet port how come
Administrators Netduma Admin Posted February 27, 2018 Administrators Posted February 27, 2018 Hi Jack - Netgear are aware of this so it's our understanding that they will be working on a fix. It's just a cosmetic error, so does not affect the performance or features.
JACKSDARIPPER Posted February 27, 2018 Author Posted February 27, 2018 Ok thanks . So keep my PS4 to port 1. Will the Geo filter still work . With this error. And should I return the router or is this something they could fix from the software. Or should I just leave everything how I had everything connected.
Administrators Netduma Fraser Posted February 27, 2018 Administrators Posted February 27, 2018 Ok thanks . So keep my PS4 to port 1. Will the Geo filter still work . With this error. And should I return the router or is this something they could fix from the software. Or should I just leave everything how I had everything connected. As Admin mentioned it's purely a cosmetic issue so your ethernet ports will work normally. The Geo-Filter will work and you can leave everything connected how it is.
