Ethernet ports not working
Hello Guys,
I am facing bad issue Netduma ethernet port doesn't work for me.
I used factory reset button but the issue remains.
wireless connection working fine.
please help out.
Hi,
Welcome to the forum.
Very strange for every Ethernet port not to be working on the router, have you tried using a different cable in case that’s what is at fault?
Hello Guys,
please help out.
Welcome to the forum. Please let us know what happens when you try another Ethernet cable - as PollutionBlues said, it's unlikely that every port would give out but not the rest of the hardware.
I have tried more than five cables.
All fails to connect to duma router.
Wireless connection works fine and am to connect to duma router.
If you connect a PC directly to the Netduma, open a Command Prompt and type in ‘ipconfig’ (without the quotes) is there an IP address next to Default Gateway? If there is can you post it here.
appreciate your help,
I have done through all these steps, I have used the following commands below:
1- ipconfig /release ; ipconfig /renew
2- ipconfig /flushdns
3- ping 192.168.1.1
4- ping 192.168.88.1 >> after router reset
5- used static IP address instead but not working.
6- I have changed the cable with other cables ( cat 5 and cat 6 ).
as mentioned earlier only wireless connection is working fine.
I have another issue, VPN page keeps loading and nothing is happening, I am not able to see nothing on the page.
3- ping 192.168.1.1
Have you tried a factory reset from the Miscellaneous page?
Yes I already did
Ok. I will leave it up to the Netduma staff to diagnose this further. Don’t worry they will get you sorted one way or another.
Could you run the ipconfig and post a screenshot of the results here please?
Hello Jack,
here is the ipconfig command output.
Ethernet adapter Ethernet:
   Connection-specific DNS Suffix  . :
   Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
   Physical Address. . . . . . . . . : 50-E5-49-B3-1C-C4
   DHCP Enabled. . . . . . . . . . . : Yes
   Autoconfiguration Enabled . . . . : Yes
   Link-local IPv6 Address . . . . . : fe80::9d63:ffd4:67a5:43c%22(Preferred)
   Autoconfiguration IPv4 Address. . : 169.254.4.60(Preferred)
   Subnet Mask . . . . . . . . . . . : 255.255.0.0
   Default Gateway . . . . . . . . . :
   DHCPv6 IAID . . . . . . . . . . . : 374400329
   DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-21-BC-B3-D6-50-E5-49-B3-1C-C4
   DNS Servers . . . . . . . . . . . : fec0:0:0:ffff::1%1
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
   NetBIOS over Tcpip. . . . . . . . : Enabled
the wireless connection was not working i have rebooted the router and it's working now.
Hello Jack,
                                       fec0:0:0:ffff::2%1
                                       fec0:0:0:ffff::3%1
On your PC, give your wired connection a static IP address. Then, connect via wireless and set a static IP address for the PC as well. If that doesn't work, hard reset on the hardware instead.
Also just to clarify, are you now getting Internet access via Wireless? And have turned off DHCP and did you change the LAN IP address?
Hello, Jack,
the internet is working fine with the wireless connection.
static IP assigned for my wired connection, the issue remains.
I am not able to ping the router gateway IP address and my cell phone IP that is connected to the wireless connection as well.
how is the hard reset goes? through the small hole on the back of the router? I already did but nothing happens.
I used factory reset from the miscellaneous page.
