possible geo filter issue?
So everything was playing fine on cod until they messed with the servers in another update for resistance my issue is I can't find a game with geo filter enabled even with the mile slider all the way up I have to disable it in order to get into any lobby. I like to keep it around 400 miles so  I can only connect to the GA server which plays best for me.
Miles 420
Strict mode on
Hmm that's strange - I haven't heard of anyone else with this issue since the latest update. Does this happen in all game modes, and do you have an open NAT? Also, which console are you playing on?
The latest update on COD has made it more difficult to find games. Like you, I have my geo-filter set for around 450miles and also covers to GA server, while staying away from Florida servers. But before the update, I might spend 25-30 seconds searching for a game lobby. Now it takes 3-5 minutes, but once I'm in a lobby all is good. Unless I have to find a new lobby a few matches later.. Whats funny is if I'm playing with friends and obviously hosting the room we will find a game lobby in seconds.. but playing on my own is when it takes forever to join a lobby
Yes it happens all game modes and I'm on xbox I also have a open nat
Could you please try turning off your console, set your radius to maximum range and then boot up your console and the game. Go to the lobby for multiplayer and then reduce your radius to your preferred size. Try searching. Does this resolve your issue?
If not, please then try expanding your Geo-Filter radius to cover all of the USA. What happens when you search for a game?
Thanks.
still, nothing but its been working halfway decent this morning and today could just be Activision isn't wanting us to get good lobbies
Ok, thanks for the update. It sounds like the router is working fine and it's on the game side, but let us know how you get on over the weekend.
today its been back to normal other than the occasional 3 to 5 min wait but that's normal for the ga server
That's good to hear - please let us know if the issue comes back. If the issue appears to have gone it's likely that there's a long term solution should it happen again :)
