Albo2001 Posted January 14, 2018 Posted January 14, 2018 After weeks of testings this is a possible fix for lag compensation and hit registration : FTTS 100/20 - Xbox One X Router Modem Fritzbox 3490 - Router Netgear Dgnd4000 with amod - Netduma MTU 1492 In FritzBox 3490 tx queue length 40/44 , i tried every possible number but nothing is different In amod - Wondershaper Settings to 2048 Dwn 512 Up Bufferbloat result A+ with 0/1 ms.. Netduma settings Sliders at 100 % Hyper 1-65535 tcp udp Both Ipv6 Off in Wan and Lan Mtu auto Deep Packet off Settings bandwitch 90/20 Geofilter settings to play in a Italy Dedis. (8/9/10 ms) Strict mode ON Range 1000 KM Congestion Control settings to 50% ( i have only 2 devices connected ) Before this my hit registration are incosistent , now is better, a lot better.. If you have any suggestion i m here.. I think this is a way where you could start.. Work for
Netduma Staff Netduma Jack Posted January 14, 2018 Netduma Staff Posted January 14, 2018 Thanks for sharing your setup! I'm sure someone else can find this useful.
Albo2001 Posted January 16, 2018 Author Posted January 16, 2018 UPDATE : In amod - Wondershaper setting Dwn 1024 Up 256.. Last Night get my first V2..
Toni169 Posted January 18, 2018 Posted January 18, 2018 Hi I read your post but don‘t understand what you mean. Did you work 3 router together? What is your real bandwith? Maybe you can help me.. I have a fritz box as main router and my netduma connected to it.. i have 25 down and 5 up bandwith what i get... Where do you typing the mtu 1492? And what is wondershaper? Maybe you can help me to get a real good connetion for gameplay in WW2!! Thx
Albo2001 Posted January 19, 2018 Author Posted January 19, 2018 1 Modem , 2 Router Fritzbox - Netgear dgnd4000 ( you could use any router that limit your bandwitch ) - Netduma.. Wondershaper is an option that amod give you at Netgear. Limit your bandwitch at 256 Up , for me is drastical changing.. Hit marker are perfect , and lag compensation is reduced.. I changed Mtu with FBEDITOR ( Software that work for fritzbox ) Sorry for my bad English , i m Italian..
