MassaDebata85 Posted January 3, 2018 Posted January 3, 2018 do you guess notice you die quiker with super turbo enabled?i feel like i get melted when its on but not so much when its disabled
BIG__DOG Posted January 3, 2018 Posted January 3, 2018 super turbo mode circumvents the congestion control rendering it useless. If you are gaming I would strongly suggest turning super turbo off. You do not need high speed s for gaming at all. When finished gaming turn super turbo back on.
MassaDebata85 Posted January 4, 2018 Author Posted January 4, 2018 super turbo mode circumvents the congestion control rendering it useless. If you are gaming I would strongly suggest turning super turbo off. You do not need high speed s for gaming at all. When finished gaming turn super turbo back on. thats kinda what i figured..whats your thoughts on turbo mode?is it just to achieve more speed?or does is affect the algorithm?
Netduma Staff Netduma Jack Posted January 5, 2018 Netduma Staff Posted January 5, 2018 thats kinda what i figured..whats your thoughts on turbo mode?is it just to achieve more speed?or does is affect the algorithm? As far as I know (without chatting to Iain about it) Super Turbo Mode is intended to disable all Congestion Control features which would otherwise be achieving very little on such high speeds. The processes involved in features such as Device Prioritisation do 'work' on speeds over 300mbps, but they just aren't needed.
