need help, havent used duma in while
Macabi83
had not been done much gaming for a while, I have had this netduma since early adopter days, I downloaded lates J version firmware, dont matter if pre/reactive on ww2 call of duty florida dedicated server, seeing huge ping spikes, 800 plus ms, my internet is fine, with low ping, 10ms or so, what has happens here, is this a glitch?
Is it just one of the others in the lobby spiking or your base ping? I’ve seen others spiking and I’m pretty sure it was said to be a glitch, if its the overall spiking probably different though.
People are trying to floor their connections to gain something, but at that point I’d hope they’d be kicked and I’ve seen it enough to assume it must be a glitch.
That is just a graphical glitch with the ping graph, your ping isn't actually 800ms. This article will help you get it sorted:
http://support.netduma.com/support/solutions/articles/16000022397-why-can-t-i-ping-
