Netduma won't work (installation)
it says that im using less than 5% of my download bandwith but i cant get any more than 5mbps on my iphone when i could get 45 previously
Is this from a speed test on the iPhone or from when you are downloading something and watching the network monitor? If it is the latter it is likely that the server you are downloading from is limiting the connection so you can't download at your full speed which is why it is only showing 5Mbps.
If it was a speed test that gave your results then could it be a wifi issue and when you test the devices do they have full speeds? :)
followed the instructions on that page but still having very slow speeds, getting 10 mbps wifi now as opposed to 40mbps up and down before. I used to get 150 up and 150 down wired and now i max out at 60mpbs up and down
Hi Elusion if you follow the instructions in the link I posted you will definitely get 120mbits wired. Maybe you need to restart the modem/router but please follow those instructions carefully. Thanks :)
ok, on a side note, how do i force myself to be host for cod aw on xbox one. Is there a way, i wanna give myself the biggest advantage possible
I don't think that is possible. Perhaps a Google search might reveal a way but I don't know of a way to do this with the Netduma. I wouldn't recommend it though as it could be considered cheating  :)
Forcing host is a very slippery slope -- I'll just leave it at that.
I have also noticed that i struggle to watch streams on twitch sometimes. It will struggle to load twitter, a video on youtube, streams on twitch. I did not have this problem before the netduma and I am the only one using the internet. I have plenty of bandwith so i do not know why its happening
Maybe you could try changing your DNS server. You can do this from Settings >> LAN and disabling automatic DNS. Maybe try 8.8.8.8 and 8.8.7.7 :)
