oatesy50 Posted June 2, 2015 Posted June 2, 2015 hi guys, i think having a bit of an issue with my netduma, When i first started using my netduma the connection was amazing (on COD AW) was winning most of the gun fights that i was in, wasn't dying around corners and the hit detection was flawless! But that doesn't seem to be the case any more, it feels like iv gone back to not having a netduma I.E dying round corners, not winning gun fights that i should and bullets not registering at all. I'm not sure if its my ISP's connection or something to do with my netduma? Was just wondering if anyone could shed a little light on this situation? Thanks!
Netduma Staff Netduma Crossy Posted June 2, 2015 Netduma Staff Posted June 2, 2015 Can you post the information listed here please
Zennon Posted June 2, 2015 Posted June 2, 2015 To check and see if it is an isp issue can you run the test http://192.168.88.1/cgi-bin/diagnose.sh
oatesy50 Posted June 2, 2015 Author Posted June 2, 2015 it wont let me post the screenshot in the post section :-/
Netduma Staff Netduma Crossy Posted June 2, 2015 Netduma Staff Posted June 2, 2015 it wont let me post the screenshot in the post section :-/ Can you follow these instructions for posting a screen shot on the forums please There is also a video in there that may be easier to follow.
Zennon Posted June 2, 2015 Posted June 2, 2015 More reply options make sure you have flash enabled in your browserIf thats not the issue use http://imgur.com/
oatesy50 Posted June 2, 2015 Author Posted June 2, 2015 Ok iv just uploaded the 4 images to imgur.com http://i.imgur.com/G5AUXEQ.png http://i.imgur.com/MR7H8De.png http://i.imgur.com/KDNNUio.png http://i.imgur.com/TjOnZWv.png My paid donwload & upload is: Down: 7Mb Upload: 1Mb And im using a wired connection from my xbox one to the netduma
Zennon Posted June 2, 2015 Posted June 2, 2015 Your connection is fine i do not see the log but its says exceptional so i am guessing under 14ms if you post the full log from the test we could tell you exactly Are you playing AW because your geo is over Ireland and the dedicated server is real bad avoid it like the plague
oatesy50 Posted June 2, 2015 Author Posted June 2, 2015 sorry forgot to post full details of ping diagnostics
oatesy50 Posted June 2, 2015 Author Posted June 2, 2015 Your connection is fine i do not see the log but its says exceptional so i am guessing under 14ms are you playing AW because your geo is over Ireland and the dedicated server is real bad avoid it like the plague I am playing AW yes and im in cornwall, tbh it does connect to the one in ireland a few times but not all the time
Zennon Posted June 2, 2015 Posted June 2, 2015 yes a really nice connection try and miss out the Ireland server i have a 316km in the uk just on the Scottish border to south uk and no euro with a ping assist of 0 so its turned off. Give that a go.
oatesy50 Posted June 2, 2015 Author Posted June 2, 2015 Ok cool, ill give it a go and let you know how it goes! thanks :-)
