cstargel5487 Posted October 17, 2017 Posted October 17, 2017 Hello all, I have lost the ability to use host filtering all of a sudden, I tried reseting router and computer but everything else will load up. any help is appreciated. Number 2 is I cant get profille settings to save and the error is for unknown reasons. Again any help would be appreciated Thanks, Steve
ColonicBoom Posted October 17, 2017 Posted October 17, 2017 I have lost the ability to use host filtering all of a sudden Number 2 is I cant get profille settings to save and the error is for unknown reasons. Again any help would be appreciated Why do you think it's not filtering? What have you got set that isn't doing what you'd expect? Profile errors are usually caused by a conflict within the choices you have, like trying to load something that is already loaded for example. I think if you have a duplicate name and things like that can cause similar conflicts when saving. Could you post screenshots please?
cstargel5487 Posted October 17, 2017 Author Posted October 17, 2017 Ill get pics but it literally wont load the host filtering page at all
cstargel5487 Posted October 17, 2017 Author Posted October 17, 2017 here is where Its getting stuck on host filtering just never loads, everything else seems to work
pollutionblues Posted October 17, 2017 Posted October 17, 2017 Try switching to the default theme and see if the host filtering page loads then.
Administrators Netduma Fraser Posted October 17, 2017 Administrators Posted October 17, 2017 As above please try that for the Geo-filter loading issue. What settings are you trying to save in your profile?
cstargel5487 Posted October 17, 2017 Author Posted October 17, 2017 Try switching to the default theme and see if the host filtering page loads then. As above please try that for the Geo-filter loading issue. What settings are you trying to save in your profile? Tried this already but I think I figured it out, I switched the cloud settings to 41 instead of 40 for destiny 2 and after switching back all is working again
